Old 01-24-2008, 03:31 PM   #3901
protc3's Avatar
Yeah, It seems to mellow the car out and keep it from binding in tight corners and hairy chicanes.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-24-2008, 04:30 PM   #3902
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by protc3 View Post
hairy chicanes.
I thought we already had this conversation
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 01-24-2008, 05:17 PM   #3903
abailey21's Avatar
Trader Rating: 36 (100%+)
The LiPo is mounted Jason, i was thinking I'm cutting 3/4ths the weight I need to drop shock oil.
I'm going to start with like 15 in the shock and 3000 in the tubes
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-24-2008, 08:26 PM   #3904
ChestyV32's Avatar
Trader Rating: 32 (100%+)
seeing how i only race carpet like 5 times a year ived tried everything in my tubes 3,5,7,10,12,15. I seem to like the 15 the most, it just makes the car so easy to drive and really predictable.
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 01-24-2008, 08:43 PM   #3905
hanulec's Avatar
Trader Rating: 27 (100%+)
thanks for the feedback everyone on the lube. i'm going to try your suggestions. does anyone know the official density of the Speedmerchant Red (medium) and Blue (thick) spooge?
a few more questions-
why is it recommended to ream out the front end steering blocks on the associated reactive caster front end? doesn't this counter act the effectiveness of the kingpin spring (the steering block moves on the kingpin before the spring bottoms out)? or does this actually keep the chassis more level?
when did people start putting a lube in the bottom pivot ball of the associated reactive caster front end?
thanks again.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-24-2008, 08:53 PM   #3906
On the front end we shim the top of the king pin to take up for the size differences in springs as they get compressed, to adjust droop (rarely), and to preload the spring. If the king pin binds on the steering block a hard knock can push the king pin up and the steering block will keep it there causing more preload then you would want.
Old 01-25-2008, 03:29 AM   #3907
Hazey's Avatar
quick question, if you want to add an extra shim to the front suspension, does it matter where you add it?
Hazey is offline   Reply With Quote
Old 01-25-2008, 04:28 AM   #3908
AdrianM's Avatar
Are you guys going to race that? With 13.5's and Lipo you will be running as fast as open mod 1/12th. Let me know...if so I will bring parts for you and Shawn on Sunday...lol!
Adrian Martinez
Old 01-25-2008, 06:07 AM   #3909
abailey21's Avatar
Were gearing down lol
Quick question, what was that "tube spooge" that PW liked so much, green slime or something???
K.C.C.O.
Old 01-25-2008, 06:22 AM   #3910
protc3's Avatar
I usually add the shims to the very top on top of the upper suspension arm eyelet. This will keep your camber gain to a minimum when you compress the front suspension.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-25-2008, 06:27 AM   #3911
protc3's Avatar
thanks again.
Im not sure on the SM lube comparables since i never tried them.
You want to ream the steering block after installing the threaded axle to keep the kingpins from sticking inside of it. What can happen in a crash is your kingpin can slide in the steering block and if the fit is too tight, it will not be able to return to position and make the car feel tweaked.
We started putting oil on the kinpins when we realized that it actually helped plant the front of the car. It slows the reaction of the spring down a bit to keep it from acting as a pogo stick. It really smoothes the car out. We dont go too heavy though. I usually run 5000 wt and i dont really mess with it too much. With the windtunnel surelube i go back and fourth with the #3 and 4
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-25-2008, 06:27 AM   #3912
protc3's Avatar
fruity
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-25-2008, 11:30 AM   #3913
How often should you replace the lube in your damper tubes and the kingpins?
kobiwan is offline   Reply With Quote
Old 01-25-2008, 11:39 AM   #3914
protc3's Avatar
I relube both each race day. I do this to make sure there is no dirt or grit in the tubes or on the pivot balls and kingpins. If they dont look bad you may be able to get 2 race days.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-25-2008, 11:49 AM   #3915
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
do you need to, and how do you remove all the old lube?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
