BMI's DB12R
#3856
When swapping out 4cell packs is it normal to have to remove the shock from its mount to slide the battery in and out?
I know this is only going to apply until tomorrow, but I am going to get some sensored motor laps without sensor cable today.
Tomorrow it's back to LiPo, to bad nobody allows them in 1/12th yet
#3857
What's the go to tyre for 19 turn carpet?
I had my car running nicely today with CRC purple front/grey rear but the rear end got very loose towards the end of the run. I suspect it might be a traction compound issue as I switched to Niftek but I'm not sure what tyre to run anyway.
My rear lower pod is cracked again too which sucks. I'm sure once I get the revised version it won't be an issue.
#3858
I may have messed up
When i look at the car from the front one of the kingpins sits a little bit closer to the ground than the other, but the ridehight is the same.
I had to squeze the suspension arms a lot to have the pivotballs move freely.
I did trim the upper arms as per manual.
Maybe I need new upper suspension arms could be deformed?
Any ideas?
Any ideas?
#3859
Trader Rating: 51 (100%+)
Hey GreaseMonkey,
Try This for tires.
Start of with:
Jaco Prism Lilac Fronts and Jaco Prism Yellow rears.
You will have better traction all the way to the end with this setup. If your track allows it use paragon traction compound.
Hope this helps
Mike
Try This for tires.
Start of with:
Hope this helps
Mike
#3860
#3861
Any ideas?
Any ideas?
#3862
R/C Tech Elite Member
Hey Jason, the package ended up arriving on Saturday, but minutes before I left for the Supercross so I didn't get a chance to get the car done for Sunday's practice. Got it all together yesterday though and this thing is ready to rock at the Snowbirds. Car looks killer!
#3863
Had a great race last weekend, the car was better than ever. The X-factor on our carpet seemed to be the GRP cyan compound front tyres. Anybody know which could be equivalent Jaco tires? At the GRP site I see completely different shores vs color codes. The cyan is supposed to be 37+42, which by GRP color codes would be magenta+purple. By Jaco 37 would be lilac and 42 something above purple.
#3864
#3865
#3866
#3867
T.M. Tires also has both front AND rear combo tires (same foam as Jaco and I think BSR). They have a cyan front tire (magenta/double purple) as well as a double black that might work for you. The Tan is a new tire that may be similar to a Jaco Yellow and their combo rear tires are called "G" compounds. You can find T.M.'s compound codes here:
http://www.tm-rc-racingcomponents.co...FrameSet34.htm
T.M.'s 12th scale offerings are here:
http://www.tm-rc-racingcomponents.co...FrameSet11.htm
