BMI's DB12R
Old 01-10-2008, 10:11 PM
  #3691
theisgroup's Avatar
i will be in monday 7pm.
theisgroup is offline
Old 01-10-2008, 10:50 PM
  #3692
ChestyV32's Avatar
Trader Rating: 32 (100%+)
its only like a 50 minute drive for me LOL LOL LOL LOL
ChestyV32 is offline
Old 01-11-2008, 08:34 AM
  #3693
protc3's Avatar
its gonna be a good time.
protc3 is offline
Old 01-11-2008, 08:36 AM
  #3694
theisgroup's Avatar
J,
Since you are getting there early, are you going to run the shuttle service from the airport for all the team drivers?
hehehe
Old 01-11-2008, 08:38 AM
  #3695
protc3's Avatar
Im going to sleep when i get there Work all day and then a 2 hour drive, Im gonna be wiped out.
protc3 is offline
Old 01-11-2008, 09:21 AM
  #3696
schreff's Avatar
Man you are a bum.
schreff is offline
Old 01-11-2008, 11:06 AM
  #3697
protc3's Avatar
protc3 is offline
Old 01-11-2008, 12:27 PM
  #3698
protc3's Avatar
Hey guys,
I wanted to announce that we are now carrying SpeedPashion Brushless systems and accessories. We will be putting them on the website this afternoon.
protc3 is offline
Old 01-11-2008, 07:11 PM
  #3699
Trader Rating: 264 (100%+)
Got my order today. Thanks Jason!
Fred Perkins is offline
Old 01-11-2008, 07:21 PM
  #3700
Kropy's Avatar
Originally Posted by theisgroup
J,
hehehe
With the Vette
Kropy is offline
Old 01-12-2008, 06:18 AM
  #3701
rcgen's Avatar
Good luck to the racers running at Minnreg today. I'll be home watching via the webcast.
rcgen is offline
Old 01-12-2008, 07:16 AM
  #3702
Sean Powers's Avatar
I finally took some pic's of my car, here they are.
Attached Thumbnails BMI's DB12R-db12r1.jpg   BMI's DB12R-db12r2.jpg   BMI's DB12R-db12r3.jpg   BMI's DB12R-db12r4.jpg
Sean Powers is offline
Old 01-12-2008, 04:09 PM
  #3703
Looking for a little help...
So another trip to the LHS gone wrong , back to the RCtech.
I have a Novak 4Cell GTB SS and a Speed Passion Ultra Sportman 13.5. The first question I have is has anyone run this combination? I was unable to get a Novak 13.5 for the moment. The second is what Spur and Pinion are you running for Carpet?
On the servo side of things, I now have a KO 949, what size screw do I need to attach the saver to the servo? Both the screw from the servo and the saver, neither one fit. In addition the ball studs will not thread into the saver, a common issue?
Also the kit comes with two screws for the servo, my Nitro bashing tells me this isnt secure, how many of you are running four screws in the servo?
Oh yeah and are you running flat or angled? If flat what do I need to change.
Also do I have to disassemble the rear end of the car to get the speed passion in?
I hate being a Nooobbbbeeee. But like a proud Nooobbbeeee I put on my newly acquired BMI Bumper today
Also what hop ups are available for this car, I dont seem to be able to decipher which parts on BMI store are hop ups if any.
deker9 is offline
Old 01-12-2008, 04:31 PM
  #3704
theisgroup's Avatar
have not run the gtb/speed passion combo
the screw for the server is the same as the motor endbell screws. the save holes are small for a reason. some actually thread the balls studs into the server and not run a nut on the back.
this is 1/12 scale, 2 screws are plenty. I run 4 just because there are 4 holes. just like I run 4 screws on the servo mount.
flat servo on carpet. the angled give too much steering that you scrub speed in the corners. you will have to shim the ball stud on the steering knuckle up. I use the stock one and shim it until a thin nut is the only thing that will hold it in place. you could use the long ballstuds(i think) that BMI has
yes for brushless motors, remove the left pod bulkhead.(4 secrews)
you can get the axle shims pair if you run jaco's new prism tires. the front arm shim set, servo saver brace, front suspension pivot ball tool is a must, 88 spur is a must for brushless (76/78 if you can find it), .018 front springs, thin flex plates, bmi shirt/sticker set.
Old 01-12-2008, 09:25 PM
  #3705
DriftDreamer06's Avatar
Hey guys,
i checked the BMI web page for pricing and could not find them? what is the price for the: gt esc? 90mm sensor cable(short)? ___mm sensor cable(long)? 13.5(is there more than 1?)?
i sent a pm as well.
DriftDreamer06 is offline
