BMI's DB12R
#3646
whats the normal tire choice for this car? small tight track,low to medium traction
#3649
trying to get some tire advice
#3650
Ive ran nothing but yellow/lilac so far and can say it is totally dialed. You can make lilac/2x pink fronts with similar results depending on the compound you decide to apply to your front tires. Lately I have been running about 2/3 compound on the fronts and its working perfect. Yellow rears seem to be the ticket for keeping the rear end of the car as free as possible while still providing the traction people want. I have been running them in both stock/19t and while they wear quite fast they work great.
#3653
Thicker dampening slows the reaction of the side springs and thinner allows it to travel more freely. When you slow the reaction down it will give the effect of more steering because it allows the side flex plates to transfer and return the energy or weight to the front tire over a longer period of time. Thinning the side dampening out has the opposite effect. The key is to find the ideal balance for your track conditions. If you go too thick it can cause the car to chatter through corners or lifting an inside rear wheel.
If the car is rolling too much and not carrying corner speed, this can be because the car is rolling too much and may need thicker fluid in the tubes. The car should be smooth and not be darty. If you get the fluid right, the car will transition smoothly and keep its cornerspeed while doing so. There are other variables also so i would start with the kit setting and save the damper fluid as one of your last adjustments.
#3656
I just put the L4 brace because everybody else are having one and the car looked like stripped without it
#3658
#3660
damn i think he is the only one ready LOL
2 more days of work and then friday im off to the races
