Old 08-03-2007, 10:17 PM   #316
darnold's Avatar
Originally Posted by mulherin View Post
darnold
whats up? I just wanted to clarify the set up. I was driving the car and what we did was go to 4deg. castor because of how tight the track was. This track has low speed turns but high bite. The blue spring was to help it rotate center and exit of turn. For a larger track start with a softer spring that will take the aggression out of the front end. Oh IRS #3 sure lube in the tubes. Good Luck!!!
Whaaattttsss uuuuppppp????? Thanks for the additional info. I am so stoked about this car. When you say softer spring do you mean front or center? BTW, is IRS #3 sure lube around 10K Diff Lube?
darnold is offline   Reply With Quote
Old 08-03-2007, 11:12 PM   #317
Trader Rating: 14 (100%+)
darnold:
Hi,
you know your going to lost since this isn't a link car.......
J/K
TimXLB is offline   Reply With Quote
Old 08-04-2007, 04:11 AM   #318
protc3's Avatar
Originally Posted by smojoe View Post
so Ti axles and turnbuckles. is a Ti screw kit next?
i did look into the ti screws but man were they expensive. we are going to have some cool aftermarket stuff eventually to upgrade the car with things such as ti screws
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-04-2007, 06:04 AM   #319
darnold,
I can't tell you what wt. the #3 (green) Sure Lube is because Rob at Murdock won't tell me.
Dave
Diffdude is offline   Reply With Quote
Old 08-04-2007, 06:10 AM   #320
haagar's Avatar
Using the very unscientific how fast the bubble rises through the bottle when you turn it upside down method, I would say # is just a little lighter than the 10K.
haagar is offline   Reply With Quote
Old 08-04-2007, 06:59 AM   #321
Aluminum screws are lighter and work very well for 1/12th scale for the most part...Except in high stress areas there's no need for anything else
Old 08-04-2007, 07:58 AM   #322
darnold's Avatar
Tim...answer your phoooooooone.
Old 08-04-2007, 07:59 AM   #323
darnold's Avatar
Thanks Dave...dangblasted, that Murdock.
Old 08-04-2007, 08:01 AM   #324
darnold's Avatar
Haagar- Thanks. It sounds like 7K diff lube should work then.
Old 08-04-2007, 10:01 AM   #325
Dave:
Hi,
I still have the same cell number and home number call me when you get a chance.
Jason:
HI,
Please add two of your new servo mounts to my order!!!!!
can't wait for your new 1/12th scale car.
Old 08-04-2007, 11:30 AM   #326
darnold that was the center spring
mulherin is offline   Reply With Quote
Old 08-04-2007, 03:44 PM   #327
darnold's Avatar
Thanks.
Old 08-04-2007, 09:11 PM   #328
AdrianM's Avatar
The instruction manual for the DB12R is 90% done. We have to do some additional photography on a production car to complete it. Jason will review it on Monday and as soon as the pics are done (it will take a week or so) we will see about posting a PDF of the complete manual
The manual will be the most complete 1/12th assembly guide seen to date. It will include a lot of tricks and tips along the way. The best part will be the setup guide in the back where Jason and I will get our big fat heads together and cover all the settings on the car in detail.
FYI, we will not release the manual until its 100% done so don't call us about it on monday
Old 08-04-2007, 09:50 PM   #329
darnold's Avatar
He's working, working, working...thanks Adrian. Now...back to work, work, work..get that manual done, get those parts bagged...get us our cars.
Old 08-04-2007, 10:07 PM   #330
Trader Rating: 23 (100%+)
Jason..........have you considered cutting the chassis so that a personal transponder would sit down in the chassis? Not that it would make a big difference, but would be cool.
SteveL is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
