Old 11-11-2007, 06:54 AM   #2761
protc3's Avatar
Im glad you like the car buddy. Depending on the traction conditions we are finding that the #3 green surelube in the tubes and stock flex plates are working really well. Going back and forth between 4 and 6 degrees of castor and different shock angles has been the only adjustments i have been messing with to control the on power steering. I run between 1-1.5mm pod droop and the rest of the setup has been box stock.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-11-2007, 08:43 AM   #2762
Here ya go. This is my setup from last night. It's hard to see, but I ran the batteries in the back position. I ran the same set of Jaco Prism's all day long. Started the rears out at 44.5 mm, and the fronts at 43.
I just noticed that I didn't enter my caster setting. I ran 6 deg. of caster. Almost wanted a little more in certain areas of the track, but any more than that would have probably just made the car too aggressive on exit.
Last edited by punkboy; 11-11-2007 at 08:46 AM. Reason: forgot to enter caster setting on setup sheet
punkboy is offline   Reply With Quote
Old 11-11-2007, 08:52 AM   #2763
protc3's Avatar
Thanks Robbie. We will get it up on the website.
Update on the website.. The online store is in the process of being setup now. It will be completed shortly so you can order right from your computer.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-11-2007, 08:55 AM   #2764
schreff's Avatar
Send a message via AIM to schreff
Default Setup so far
Hey fellas, here's the setup I ran last night. It's still a work in progress.
-Front-
Parma Pro38 Magentas cut to 1.68"
.018 Springs
Losi Brown grease on king pins
Caster shims 1 in front and 1 behind the upper arm
-2 degrees camber
1 degree total front toe out
#2 BMI ride height shim
-Rear-
Parma Pro38 Greys cut to 1.74"
.068 Side Plates (kit stock)
#3 WindTunnel damper fluid in tubes
35wt Losi oil in Center shock
Associated gold spring
Shock length was 2.66"
Shock mount raised 2mm
IRS 3.5 ride height adjuster in down position
I think that's the pertinent info. Body was a Parma Speed 8 HD LW. I ran 19t with an Orion Element geared at 88/32. It ran strong for 8 minutes too. I tried changing camber to -1.5 and putting both caster shims back on the upper arm, but I really didn't get a chance to see what the car would do with the center shock collar loosening on it's own. That'll be fixed for this weekend though.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 11-11-2007, 09:47 AM   #2765
Can we add the additive type used please? It's going to be important because here in Europe we are exclusively Jack, and many of your set-ups aren't going to be much help if they are on Paragon.
Hope someone can add it to the set-up sheet. If not can we all remember to put it in the box for the carpet type? Thanks.
SlowerOne is offline   Reply With Quote
Old 11-11-2007, 09:49 AM   #2766
AdrianM's Avatar
PW and I tried to get that added before the Mi3 was released. Schu UK didnt want to change what they already had done on the sheet so don't hold your breath about them adding it.
Adrian Martinez
Old 11-11-2007, 10:32 AM   #2767
schreff's Avatar
My setup was using Paragon. I believe Robbie was using Paragon as well as that's the traction used at Mimi's.
-Jason Schreffler-
Old 11-11-2007, 10:39 AM   #2768
Yup, you got it!
Paragon Fo' Lyfe
Old 11-11-2007, 11:34 AM   #2769
redlion's Avatar
Hey Robbie, Thanks for the help yesterday!!
It was a good day of racing at the Roar Region 2 race at Mimi's.
My car was dialed all day long. BMI had top 3 in the A main.
I got lucky and was able to get around Robbie for secound.
Wes Lion
redlion is offline   Reply With Quote
Old 11-11-2007, 11:40 AM   #2770
Regional Moderator
CarbonJoe's Avatar
Hi Guys -
I slightly improved the 1-12 rollout spreadsheet. Now all you have to do is change the spur tooth count in the first row, hit enter, and you're done. The original didn't modify the title if you changed the spur. Also, every other column is yellow to make it easier to pick the correct info. And I modified the formula to use Excel's PI() function.
CarbonJoe is offline   Reply With Quote
Old 11-11-2007, 11:44 AM   #2771
Regional Moderator
CarbonJoe's Avatar
Hmm, now I'm confused... You're talking about the Mi3 setup sheet, right? Why would Schumacher make up the BMI setup sheet?
Old 11-11-2007, 01:17 PM   #2772
mike ivy's Avatar
Trader Rating: 50 (100%+)
Anyone with a BMI DB12R Car Jason's setup is the way to go for Horsham his car was flyin
-Front-
.018 Springs
-2 degrees camber
-Rear-
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-11-2007, 01:44 PM   #2773
Trader Rating: 239 (99%+)
I am sure I am beating a dead horse here but, this car is the BEST 1/12 I have ever driven! I have never liked 1/12 scale and this car has changed my mind! Awesome work Jason!
I ran the ROAR Region 2 Regionals this weekend and actually qualified in the A! Then to finish the race in 5th was great!
Still having problems with corner speed but it's getting closer to the way I like to drive every adjustment I make.
Thanks BMI!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 11-11-2007, 05:25 PM   #2774
protc3's Avatar
That is great to hear fred. Im sure you will get it the way you want it. The car reacts well to small changes. Thanks for the kind words
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-11-2007, 05:27 PM   #2775
protc3's Avatar
Originally Posted by CarbonJoe View Post
Hi Guys -
Thank you very much buddy I really do appreciate all the help you guys offer for BMI. You help us be the best we can be
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
