Old 10-31-2007, 11:59 PM   #2566
Trader Rating: 7 (89%+)
Originally Posted by march to my own View Post
Dave,
I felt for ya in your main man. Only one other car to run against. How did the testing go?
You mean one other car to have them drive full speed into Dave?
Johnny Carey is offline   Reply With Quote
Old 11-01-2007, 04:15 AM   #2567
protc3's Avatar
Originally Posted by Kave View Post
How much are the cars going for right now?
The car is available 2 ways,with and without tires. With tires is $269.99 and without tires is $250.00.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-01-2007, 04:25 AM   #2568
protc3's Avatar
Its cool that dave ran prototype tekin product. He basicly didnt put himself first. Most guys forget what sponsorship is about. Helping companies develop there products is what helps them grow. Big race or not, at the end of the day we are all still a bunch of overgrown kids racing for bowling trophies.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2007, 04:45 AM   #2569
Kropy's Avatar
Send a message via AIM to Kropy
I'm telling Mom what you said.........
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 11-01-2007, 04:54 AM   #2570
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2007, 05:04 AM   #2571
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Jason, thats again for the info yesterday and CONGRATS.. You not NOT the weakest link.... I am..... The set-up sheet ( Rev. 1, cleaned, enhanced version ) is almost ready and it will be sent to the your office manager tomorrow... BTW which format do you think is better portrait or landscape?
I've "borrowed" the BMI logo to put on it..... Once its done you can convert it to a pdf file from the visio/jpg file....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 11-01-2007, 05:58 AM   #2572
protc3's Avatar
portrait would work
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2007, 06:58 AM   #2573
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
Originally Posted by Kropy View Post
What kind of roll out has everybody been using for stock & 19 turn BRUSHED motors?
At the Halloween race with a stock motor i ran ratios all over the place. Ran one qualifier at 1.73 and the next qualifier at 1.93 but settle for a 1.79. 1.79 was recommended by one of the guys that was on TQ pace every qualifier and that gear gave me my fastest run as well. All this with a CO-27, on a somewhat tight and small carpet track.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 11-01-2007, 09:24 AM   #2574
Anyone willing to share their set-up from the Halloween Classic? I'm looking to prepare for stock class in Cleveland.
Thanks, Denney
Denney is offline   Reply With Quote
Old 11-01-2007, 09:43 AM   #2575
protc3's Avatar
This is Craig Xavier's set up from this past weekend at the classic. This was pretty much his 2nd or 3rd time running the car so he may change it some in time.
Halloween Race at The Gate Setup:
Kingpin Lube: 10,000
Springs: .020"
Camber: 1.5 deg
Caster: Max(Both shims back)
Toe: none
Upper Mount: 10
Up Travel: none
Servo: Flat
Steering Ballstud: Med + .5mm shim
Front Ride Height: 3.5mm
Front Width: 164mm
Shock Oil: 35wt Losi
Shock Spring: AE Copper
Shock Length: 65mm
Rear Pod Droop: 1mm
Forward Shock Ball Stud: Long
Spacers Under Fwd Ball Stud: 1.5mm
Flex Plate Thickness: .070"
Flex Plate Preload Screws: No
Rear Ride Height Adjusters: IRS 3mm
Battery Placement: Back
Rear Ride Height: 3.5mm
Rear Width: 172mm
Tube Lube: 10,000
Body Parma Speed 8 LW
Rear Body Mount Position: Back
Battery: Express Motorsports EP4200
Motor: Express Motorsports CO-27
Brushes: F-brush
Springs: Red
Pinion: 31
Spur: 95
Diff Grease: AE
Speedo: Tekin FX Pro
Receiver Pack: No
Weight: 830 g
Tire Compound: F: Dbl Pink/R: Yellow Jaco
Tire Diameter: F: 42mm/R: 44.5mm
Wheel Diameter: Oversize
Axle Shims: As Needed 172mm Width
Half compound front tires/Full compound rear tires
Jack the Gripper as per track rule
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2007, 09:47 AM   #2576
Tim Stamper's Avatar
I think that answers the questions that I had sitting in my head as I build the car.
Thanks for posting that Jason!
Tim
Tim Stamper is offline   Reply With Quote
Old 11-01-2007, 10:36 AM   #2577
Budman's Avatar
Trader Rating: 22 (100%+)
I put my car together last night and all I can say is WOW!!!!!! The fit and finish is second to none. Everything fit perfectly and thanks Jason for having predrilled servo holes. That made life much better. Can't wait to get on some carpet this weekend.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 11-01-2007, 11:13 AM   #2578
protc3's Avatar
Thanks buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-01-2007, 12:54 PM   #2579
Slapmaster6000's Avatar
Trader Rating: 14 (100%+)
portrait would work
Jason, are you guys working a editable set up sheet? Tom (one of the guys in our little BMI group) is going to work on an Excel style set up sheet that will be cable of info sharing to the entire community. If you guys build something like XRay, then the Excel format will be out the window. How cool will it be, to have an attachment file with Craig's set up from The Gate and not have to do all that typing?
Slapmaster6000 is offline   Reply With Quote
Old 11-01-2007, 02:27 PM   #2580
protc3's Avatar
The setup sheet is an excel file. I will see if i can find someone who can make it editable from the website. Anything anyone feels they can help with i will be happy to look at.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
