Old 10-24-2007, 02:34 AM   #2431
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey robk ygpm have a solution for your setup for ya, hope it helps
Originally Posted by robk View Post
I have a couple questions for stock motor racing:
Has anyone tried .022 springs? I had put them on initially because I felt like the front end was diving around, and i wanted to flatten it out. I took them off because my car was pushing a bit, which may have been more the tires. I was trying gray fronts at the time. However, I had my fastest laps this way.
I have heard of guys with other cars claiming going up on the spring can make the car cut more, if not steer more. Seems like this is with the old school front end more...?
I also went to more caster (shims back), heavier spring (copper, them SM black), 7000 wt instead of 5000wt trying to get the car to get thru the middle of the turn and finish the corner better. Going to a Dbl. Pink / gray combo helped the most. I have noticed that I want more mid/exit steering on a consistent basis...any ideas? I'm trying to get this thing sorted for the Halloween Classic, and i'm going to the local track tomorrow, so fire away
Ending setup for the night
Front
.020 spring w/ 1 .010 shim preload
10* block
max castor
1.5* camber
Servo flat, outer ballstud shimmed up 3mm
dbl pink 1/2 sauce 1.70 (track was kinda green at first)
.5 toe out
4mm ride ht
stock width (no shims)
Rear
35wt Losi/Speedmerchant black spring
Corally long ballstud ~2mm taller than stock
1mm droop
chassis & pod flat
.066 flex plate no screw
7000 wt damper lube
grey full sauce 1.80
4mm ride
battery middle
172mm wide
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-24-2007, 03:08 AM   #2432
Trader Rating: 71 (100%+)
RobK,
Have you tried white rears? Try white rears with double pink fronts on 20 front springs. You may need to go back to the copper center spring. One thing to watch out for with whites is traction going away late in the run.
RBLove is offline   Reply With Quote
Old 10-24-2007, 05:22 AM   #2433
RichChang's Avatar
Hi Jeff,
I don't claim credit for coming up with this solution - one of my racing buddies showed me this.
Basically, you trim the fiberglass backing plate flush with the motor end-bell. Then, bend the tabs backwards and trim them to proper length.
I've attached a pic.
-Rich
Originally Posted by jgee888 View Post
Hey Rich,
What did you do to your motor to make the body sit lower. Did you trim the tabs? Any chance you can post a pic. I'm trying to lower the body on my DB12R without having the body hit the motor tabs.
Thanks,
Jeff
RichChang is offline   Reply With Quote
Old 10-24-2007, 05:34 AM   #2434
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by RichChang View Post
Hi Jeff,
-Rich
You, Have a buddy..........
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-24-2007, 05:41 AM   #2435
Hi Jeff,
-Rich
Thanks Rich, I'll try the mod this weekend.
Jeff
jgee888 is offline   Reply With Quote
Old 10-24-2007, 05:46 AM   #2436
AdrianM's Avatar
Front
10* block
max castor
1.5* camber
.5 toe out
4mm ride ht
Rear
1mm droop
chassis & pod flat
7000 wt damper lube
4mm ride
battery middle
172mm wide
Try less castor and thicker flex plates.
Adrian Martinez
Old 10-24-2007, 06:12 AM   #2437
RichChang's Avatar
Yeah, and he requires I hook up a bike-tire pump to him every few days to keep him inflated.
Hmm.. I'm not sure I should have made that joke with this crowd.
-Rich
Old 10-24-2007, 06:55 AM   #2438
Kropy's Avatar
-Rich
Sounds like that part in Austin Powers "I swear it's not mine man".........LOL
Kolors by Kropy
Old 10-24-2007, 09:08 AM   #2439
robk's Avatar
Trader Rating: 22 (100%+)
thanks for the help guys
Old 10-24-2007, 09:49 AM   #2440
EricF's Avatar
Originally Posted by BSchorr View Post
Originally Posted by Kail [View] This was post #2238, what of it? dont explain about the body posts...
sorry I ment to type 2388. sometimes it hard to play on the net and work at the same time
EricF is offline   Reply With Quote
Old 10-24-2007, 01:31 PM   #2441
redlion's Avatar
Jason you have email.
Wes
redlion is offline   Reply With Quote
Old 10-24-2007, 02:13 PM   #2442
Regional Moderator
CarbonJoe's Avatar
Originally Posted by protc3 View Post
Dave Arnold,
I sent your package out for the classic. It will arrive at the address you gave me on thursday.
I sent a bunch so if any of the team guys or customers need help,we will be able to support there needs
Jason -
Did you include some of the aluminum front end spacers in what you sent to the Halloween Classic? I need to pick up a set.
CarbonJoe is offline   Reply With Quote
Old 10-24-2007, 03:14 PM   #2443
protc3's Avatar
Actually,no. I will see what the price is on next day shipping and if its not extreme i will send them out tommorow
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-24-2007, 03:29 PM   #2444
protc3's Avatar
Hey rob,
Try running the pod .5mm tilt with the front of the pod being .5mm lower than the rear of the pod and then set your uptravel over ride height to 1mm. What this will do is give you less pod lift or antisquat under acceleration and do away with some of the push you are getting. At the same time it will still allow you your 1mm uptravel to help absorb the bumps. This gives more overall steering from my experience. Let me know how it goes.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-25-2007, 06:43 AM   #2445
redlion's Avatar
Good luck to the BMI team heading to, The Gate this weekend!!!
Wes
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
