Old 10-23-2007, 11:59 AM   #2416
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Anyone else have trouble removing and installing novak brushless motors? I know when Jason said he designed the rear pod for brushless, but mine will absolutely not drop in, I have tried all possible angles and such, so i ended up loosening the left axle mount to slide the novak brushless in.. If only the rear mounts were like 2mm more apart hehe. unless im missing something
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-23-2007, 01:00 PM   #2417
protc3's Avatar
the brushless motor will fit just fine. You do need to loosen the left side screws to install the novak. The LRP fits without. The pod is designed to fit the motor with no interferance of the tabs and also allow for larger than usual pinions. I could have spread the pods further apart but that would have made the pods specific to the Prism wheels and cut parma drivers out of the picture. The 2 wheels have different offsets and i dont want to limit my market. The important part is that the motor will fit with no dremel action and you can gear the motor to where it needs to be. In order to make them fit without loosening the screws on 1 side i would need to do a 3 bolt pod which is considerably weaker and the flex characteristics are not symetrical like i wanted. I wanted the pod to fit brushless but with no sacrifice to performance.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-23-2007, 02:17 PM   #2418
RichChang's Avatar
Hi Jason,
I also had problems installing and removing my Novak 10.5 and 5.5 via the top of the pod. However, there were a couple times I got the 10.5 to go in by jiggling it around b/c it got wedged and it finaly dropped in.
When I put the 5.5 in this past Sunday, I removed the entire pod assembly from the bottom graphite plate to remove the 10.5 and put the 5.5 in. I do things the hard way. LOL! But, now I know to just loosen the screws you mentioned.
Not a big deal for me, tho, because I don't/won't be changing motors again. I'd rather have it all balanced out than get ease of motor removal. :-)
-Rich
RichChang is offline   Reply With Quote
Old 10-23-2007, 04:06 PM   #2419
Originally Posted by RichChang View Post
- Parma speed8 body and lowered as much as possible (I had to do some modification to the brushless motor so the body could sit lower). Front body posts: 2nd hole from bottom. Rear body posts: 3rd hole from bottom.
Hey Rich,
What did you do to your motor to make the body sit lower. Did you trim the tabs? Any chance you can post a pic. I'm trying to lower the body on my DB12R without having the body hit the motor tabs.
Thanks,
Jeff
jgee888 is offline   Reply With Quote
Old 10-23-2007, 04:52 PM   #2420
EricF's Avatar
Originally Posted by jgee888 View Post
Hey Rich,
Thanks,
Jeff
goto page 80 post #2238
oops, that should have been 2388
EricF is offline   Reply With Quote
Old 10-23-2007, 05:53 PM   #2421
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
is there a pic, there is no such thread on that page btw
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 10-23-2007, 05:58 PM   #2422
protc3's Avatar
Hi Jason,
-Rich
Thats cool rich. To be honest, The nice part about brushless is that you are not taking the motor out often. My main concern was that the motor was secure,No Tab interference, and there was room for gearing. I did mess with a 3 bolt pod and with the brushless motor weighing more, The pod was not strong enough. In an impact the motor side bent real easy. Without the added structure, the pod flexed under impact from the forward shock of the heavier motor and bent the pod something severe. The motor wants to keep going forward. I dont believe in putting any gimic out there. I want the parts to do there job and do it well
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-23-2007, 06:08 PM   #2423
Trader Rating: 65 (100%+)
Send a message via AIM to joey
heres a pic of my car with the brushed setup in it..
=Joe Wright=
joey is offline   Reply With Quote
Old 10-23-2007, 06:15 PM   #2424
darnold's Avatar
Awesome Jason, thank you very much! Anyone going to the Halloween Classic that needs some support will be helped as much as possible.
darnold is offline   Reply With Quote
Old 10-23-2007, 06:41 PM   #2425
Send a message via AIM to goop
hey dave how is it going good to see your going to be at the gayte this weekend. just make sure you keep an eye on your pit board
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 10-23-2007, 07:03 PM   #2426
BSchorr's Avatar
Originally Posted by Kail [View]
Anyone can tell me if lilac /yellow combi works better than purple/grey for stock using crc carpet? I am wondering if i should try.
it depends on a few factors....but what traction compound are you allowed to use?
This was post #2238, what of it? dont explain about the body posts...
Old 10-23-2007, 07:08 PM   #2427
darnold's Avatar
Goop, Goop, Goop, keep your hands and drawings to yourself...you lil' pervert.
Old 10-23-2007, 11:37 PM   #2428
robk's Avatar
Trader Rating: 22 (100%+)
I have a couple questions for stock motor racing:
Has anyone tried .022 springs? I had put them on initially because I felt like the front end was diving around, and i wanted to flatten it out. I took them off because my car was pushing a bit, which may have been more the tires. I was trying gray fronts at the time. However, I had my fastest laps this way.
I have heard of guys with other cars claiming going up on the spring can make the car cut more, if not steer more. Seems like this is with the old school front end more...?
I also went to more caster (shims back), heavier spring (copper, them SM black), 7000 wt instead of 5000wt trying to get the car to get thru the middle of the turn and finish the corner better. Going to a Dbl. Pink / gray combo helped the most. I have noticed that I want more mid/exit steering on a consistent basis...any ideas? I'm trying to get this thing sorted for the Halloween Classic, and i'm going to the local track tomorrow, so fire away
Ending setup for the night
Front
.020 spring w/ 1 .010 shim preload
10* block
max castor
1.5* camber
Servo flat, outer ballstud shimmed up 3mm
dbl pink 1/2 sauce 1.70 (track was kinda green at first)
.5 toe out
4mm ride ht
stock width (no shims)
Rear
35wt Losi/Speedmerchant black spring
Corally long ballstud ~2mm taller than stock
1mm droop
chassis & pod flat
.066 flex plate no screw
7000 wt damper lube
grey full sauce 1.80
4mm ride
battery middle
172mm wide
Old 10-24-2007, 12:09 AM   #2429
G Mills's Avatar
Finally get to put the new car to the test this weekend. Can't wait!
G Mills is offline   Reply With Quote
Old 10-24-2007, 12:49 AM   #2430
BSchorr's Avatar
G Mills - Looks clean man, I am going to re-do my car as I want to make my servo flat instead of angled and my GTB 4-cell is pushing on my servo, Ill get some pics after i get meh new lid mounted.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
