Old 10-22-2007, 04:55 PM   #2401
RichChang's Avatar
Originally Posted by AdrianM View Post
Thats a nicely laid out car! Everything that can be on the right is on the right to offset the weight of the speedo. There is a nice amount of motor wire so it can freely flex s the rear pod move...good stuff!
Thanks, Adrian. That's super cool coming from you (especially since I know you worked with PW and his car layouts and wiring are works of art). The battery wires are a little shorter after this past Sunday (I changed the orientation of the tabs they solder to on my battery packs). That pic was taken after rewiring the car 3 times. The first time was after I had finished building the car initially and found out I had the servo mounts in the wrong holes. The second time was when I decided I wanted to flatten out the servo. And, the third time was when I decided I wanted to try lengthening the center shock. I'm not good at planning ahead, eh? Haha!
If you look closely at the pics you can kinda seem the gleam of the flash off of the lower arm spacers. LOL!
Originally Posted by Apex View Post
Rich - What servo are you using?
Also, are the .175 flex plates the stock G10 flex plates?
Apex - I'm using the Futaba 9602. I think those are the stock flex plates? I bought a bunch of them from Jason when I purchased the car and dumped them all in a pile while I measured them so I don't remember which ones came with the car. I put those on because that is the thickness I had used when I ran a T-bar car a loooong time ago.
Originally Posted by Kail View Post
Is the tweak board very good? I am really interested in it
Kail - I love that board. It also works for 1/10th and 1/8th scale cars. Folks at the track often times ask me to use it.
Originally Posted by redlion View Post
What bumper is that and do you have a part number??
Wes
Redlion - Slapmaster is correct, it is the one CEFX makes for their car. I had to redrill the holes (they were close, but not close enough). You are better off getting the bumper from Slapmaster since it is made for the BMI car and is also a great bumper. Normally I would not run such a wide bumper like the one on my car (CEFX does make a narrow version) but the material Josh uses doesn't bend back very easily and I have a bad habit of clipping corners.
-Rich
RichChang is offline   Reply With Quote
Old 10-22-2007, 05:49 PM   #2402
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Jason, ygpm question for ya
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-22-2007, 05:59 PM   #2403
Trader Rating: 239 (99%+)
Whats the consensus on cutting down the roll over antenna w/ the new DSS systems? My antenna only comes halfway up on the antenna post.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 10-22-2007, 06:00 PM   #2404
Mike,
Are you going to Zaks this weekend?
Old 10-22-2007, 06:24 PM   #2405
ChestyV32's Avatar
Trader Rating: 32 (100%+)
dont roll over
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 10-22-2007, 07:36 PM   #2406
AdrianM's Avatar
Hey Fred!
Keep it full length...we still need it as a roll over antenna. We had a guy locally try to run with no antenna and while the radio worked perfectly, unlike sedans most of the time an upside down 1/12th will never get right side up without help....and they slide FOREVER and hit HARD when they stop
Adrian Martinez
Old 10-22-2007, 07:41 PM   #2407
Kropy's Avatar
Send a message via AIM to Kropy
Sounds like the voice of experience talking..........LOL
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-22-2007, 07:43 PM   #2408
ChestyV32's Avatar
SXT Tire Additive
Old 10-22-2007, 07:48 PM   #2409
AdrianM's Avatar
It was Shad Gallante...
Cheston...I think you where there when it happened so STFU...lol!
Adrian Martinez
Old 10-22-2007, 07:58 PM   #2410
ChestyV32's Avatar
ohhhh I remember that he thought he would be alright and wouldnt need an antenna but he lost like almost a lap because of it
SXT Tire Additive
Old 10-22-2007, 10:48 PM   #2411
Been there...done that...lol
Old 10-23-2007, 06:01 AM   #2412
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Fred, my Roll over antenna, is only about 1/2 as tall a stock one. It still performs it's intended objective, and works fine. I did not cut it down on purpose, just broke it at a race, trimmed it up, and have never replaced it.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-23-2007, 07:14 AM   #2413
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
what do you guys reccomend for prism tires for crc carpet 13.5 racing, and also for 6.5 mod. I am not real familiar with the jaco's I usually run BSR.
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 10-23-2007, 09:18 AM   #2414
AdrianM's Avatar
For 13.5 try double pink fronts and yellow rear. If you need less steering try lilac fronts. The Yellow rears are a low rubber foam that generates less traction. This makes the car more free and efficient with the limited power you get from stock and 13.5 motors. Low rubber foam like Yellow, Grey and White do not have enough forward traction to run 19T/10.5 and mod. You will light up the tires out of the corners.
For 19t/10.5/Mod run double pink fronts and double pink rears.
Adrian Martinez
Old 10-23-2007, 11:13 AM   #2415
protc3's Avatar
Dave Arnold,
I sent your package out for the classic. It will arrive at the address you gave me on thursday.
I sent a bunch so if any of the team guys or customers need help,we will be able to support there needs
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
