Old 10-22-2007, 05:00 AM   #2386
protc3's Avatar
I would try forward battery location and see if that lets you lighten up on the side dampening. 7000-10000 doesnt sound all that bad though. Let me know if that helps
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-22-2007, 06:14 AM   #2387
RichChang's Avatar
Originally Posted by protc3 View Post
Thats awesome dude!!! When you get a chance, post your setup or email it to me and we will put it on the website.
My setup is not very far from the recommended setup you and Adrian use.
Front End:
- 10 deg blocks
- .020" springs shimmed with 1 washer preload (no slop)
- 2 deg camber
- 1 deg toe-out each side
- upper arm in middle position
- Servo flat
- Kimbrough white servo saver with CEFX ball-studs in lower holes
- high ball-studs on steering knuckles to make steering links pretty much flat (they are a touch higher at the knuckles)
- BMI front arm shims
Center Shock/Side Suspension:
- long length (I moved the antenna mount forward a hole to make the shock longer. If you do this you need to put a longer ball-cup on the bottom end.).
- 35 wt AE, gold spring
- I don't remember the length but I have 1.5mm of droop (so if I lift the car at the center and measure ride height, it reads 5mm)
- stock ball-stud
- 5000 wt Mugen diff lube for side dampers
- .175 flex plates
Width:
- Front: stock width (no extra shims behind front tires)
- Rear: 172 mm
Motor:
- Novak 5.5 w/sintered rotor
- 1.30" roll-out (with 96 tooth spur)
Other:
- Front tires: Double-pink, 1.64", 1/2 Paragon
- Rear tires: Pink, 1.71", full Paragon
- 3.5mm ride height - pretty much flat front, mid, and rear
- My turning diameter when checking circles is a little less than 4 feet. Car has very good off-power and on-power steering. Corner speed is excellent.
- battery in middle position
- Parma speed8 body and lowered as much as possible (I had to do some modification to the brushless motor so the body could sit lower). Front body posts: 2nd hole from bottom. Rear body posts: 3rd hole from bottom.
- track was medium/high bite with sweepers at each end, and a fairly tight but flowing infield.
Pics are on my camera, I just need to get them off of that and upload them.
-Rich
Last edited by RichChang; 10-22-2007 at 06:42 AM. Reason: mistyped camber and forgot toe
RichChang is offline   Reply With Quote
Old 10-22-2007, 06:29 AM   #2388
RichChang's Avatar
Default Pics of my car
Here are pics of my car.
-Rich
Old 10-22-2007, 09:00 AM   #2389
How do you guys accurately measure toe?
Thanks,
Chris
ckearns is offline   Reply With Quote
Old 10-22-2007, 10:08 AM   #2390
RichChang's Avatar
Thanks,
Chris
I use the setting tool from unitytool.com found here: http://www.unitytool.com/Unity_Tools...ek_boards.html
-Rich
Old 10-22-2007, 10:15 AM   #2391
AdrianM's Avatar
Thanks,
Chris
Use a pair of calipers to measure the distance from the inside of one tire to the inside of the other tire at the rear, then at the front. The diffrence is your toe in/out expressed in mm or inches, whichever you prefer.
We typically run between .5mm total toe-out....that means the measurement at the front is .5mm wider than at the rear
Adrian Martinez
Old 10-22-2007, 10:21 AM   #2392
AdrianM's Avatar
-Rich
Thats a nicely laid out car! Everything that can be on the right is on the right to offset the weight of the speedo. There is a nice amount of motor wire so it can freely flex s the rear pod move...good stuff!
Adrian Martinez
Old 10-22-2007, 10:28 AM   #2393
Trader Rating: 45 (100%+)
Rich - What servo are you using?
Also, are the .175 flex plates the stock G10 flex plates?
Apex is offline   Reply With Quote
Old 10-22-2007, 10:44 AM   #2394
Kail's Avatar
-Rich
Is the tweak board very good? I am really interested in it
Kail is offline   Reply With Quote
Old 10-22-2007, 02:02 PM   #2395
Slapmaster6000's Avatar
Trader Rating: 14 (100%+)
Default DB12R Foam Bumpers
Hey gang, got the bumpers under way. Took some quick photos. Going to see if I can get a batch out to Jason right away. I will have some available as well. They are not up on my site yet, but very soon. Part #115.
Brian-www.slapmastertools.com
BMI's DB12R-p1010001.jpg   BMI's DB12R-p1010003.jpg   BMI's DB12R-p1010006.jpg   BMI's DB12R-p1010007.jpg   BMI's DB12R-p1010012.jpg
Slapmaster6000 is offline   Reply With Quote
Old 10-22-2007, 02:09 PM   #2396
redlion's Avatar
What servo are you using?????
Wes
redlion is offline   Reply With Quote
Old 10-22-2007, 02:12 PM   #2397
redlion's Avatar
-Rich
What bumper is that and do you have a part number??
Wes
Old 10-22-2007, 02:18 PM   #2398
Rich looks to be using a CEFX bumper. I say that because it's green. The post holes are close enough that it works. I made one specifically for the DB12R. I reported earlier incorrectly on the weight, they are actually 4 grams. I am using a JR 3660.
Old 10-22-2007, 02:27 PM   #2399
redlion's Avatar
Thank you!!
Wes
Old 10-22-2007, 04:03 PM   #2400
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey CraigX wasup ygpm
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
