Old 10-19-2007, 09:18 PM   #2326
darnold's Avatar
I want some...ride height adjusters for bigger bearings.
darnold is offline   Reply With Quote
Old 10-19-2007, 09:28 PM   #2327
Scottrik's Avatar
Trader Rating: 241 (100%+)
Originally Posted by protc3 View Post
I will make some ride height adjusters for the bigger bearings in my lathe and see if i can make them for a reasonable price. It shouldnt be a problem. I can machine some out of delrin. I will keep you posted and post some pics when they are finished. I will knock off a set tommorow.
THOSE I might be interested in!
Q for Brian or Jason...are the larger od bearings easy to source? I've never looked.
**EDIT** NM, I just checked the Boca site, several grades to choose from. Might be a winner idea to stock a couple different grades to sell with the adjusters Jason.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-19-2007, 09:30 PM   #2328
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Dave why were you so mean to me at the midwest allstar series ?
wallstreet is offline   Reply With Quote
Old 10-19-2007, 09:31 PM   #2329
Kropy's Avatar
Send a message via AIM to Kropy
+1
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-19-2007, 11:02 PM   #2330
AdrianM's Avatar
Originally Posted by Slapmaster6000 View Post
Jason,
One of my pet peeves with 12th scale has been the ride height range of the rear adjusters in the rear pods. Its been probably a decade since the on-road 10th scale cousin has vanished and yet we still have no use for a ride adjuster in a middle possition let alone, flipped over. At some point, does it make sense to lower the axle slot in the rear pods so that we are not using only #1 &#4's or #3.0 & #3.5? I guess where I am going with this is.... ta da.... mold up some ride blocks that will take the 1/4 x 1/2's. I think that I spent $17 a bearing at Boca for that ceramic that lasted 2 years. And these bearings got used a couple a times a week for 6 months during regular season. I know as Slapmaster Tools, I wont do anything with this idea... only because the car guys have to change the rear bulkheads first.
****** Anouncement*******
Slapmaster Tools will have foam bumpers for the DB12R to help protect our investment! I have a proto-type on my ride, I took a hit last week that should have required a dust pan to clean up. I wiped the black mark off of the body and I would have never known differently. No body dents from the chassis, no post hole earthquakes, the front end was still on the car and they weigh only 2 grams. Jason has expressed interest in carrying the bumper at his shop as well. I should have the bumpers today. I should be able to get Jason a batch late next week (if all goes well). I have a 3 day event that I will be attending within the hour and will not be around to answer any more questions. SMT #115 DB12R Foam Bumper, $7.
Brian-www.slapmastertools.com
1/10th oval cars use the same rear pods and ride hight adjusters as we do in 1/12th but they flip the cams so the axles are high. They do this to get low ride height with 1/10th wheels.
Oh...and get a bumper to Jason ASAP! He keeps punching chassis shaped holes in Kropy's awesome painted bodies...lol!
Adrian Martinez
Old 10-19-2007, 11:04 PM   #2331
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Dang it, bumpers were a no show today! That throws a little wrench into my plans of selling out of them this weekend.
I hate to say this, but its been a struggle with the DB12R today. Probably for a couple of reasons. The track layout has been changed plus the direction! Not only do we need to groove up a new line, we need to get the carpet fibers laying the right direction. I threw a lot of tires at the car today and came up with various degrees of fast, but only for a few minutes. The Yellow Black yeilded an 8 minute car, but likely at the expense of the lap times. I am hopeful that we'll get back on the yellow lilac's by mid day Sat. We have set up a mini BMI DB12R team inside SIR with 7 cars/drivers. We are bouncing ideas and set up successes and failures to all. Hopefully as a group, we'll cover the A Main. If you are interested in following the results of the race, go to the Northwest Racers section and look up results under the NWIC or SIR threads.
Big bearings.... see Jason.... maybe I'm not nuts after all!
Slapmaster6000 is offline   Reply With Quote
Old 10-20-2007, 01:19 AM   #2332
corallyman's Avatar
Trader Rating: 97 (100%+)
If anyone is interested the action is being covered by liverc.com
I believe also Brian.
Steve
corallyman is offline   Reply With Quote
Old 10-20-2007, 03:13 AM   #2333
protc3's Avatar
Brian, Give me a buzz at the shop and i will give you guys a hand. I will be there until noon today
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-20-2007, 03:22 AM   #2334
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Its 5am on a saturday, go back to bed!
Kave is offline   Reply With Quote
Old 10-20-2007, 03:24 AM   #2335
protc3's Avatar
I gotta go to work.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-20-2007, 05:29 AM   #2336
Kropy's Avatar
I gotta go to work.
Me too............................................... ...................................At the track
Kolors by Kropy
Old 10-20-2007, 05:50 AM   #2337
protc3's Avatar
PUNK!! I dont get to run until the end of november
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-20-2007, 06:07 AM   #2338
darnold's Avatar
Walls- Who meeee????? I can guarantee that it was an aberration
in your imagination!!!
You going to the IHobby show today? If so I will see you there, or come up to race tomorrow.
Old 10-20-2007, 06:42 AM   #2339
Jason, will do. I think that Brad has you on speed dial. In the meantime, all cars seem to be fast for 3-6 minutes depending on tire combo and then go into push mode, adding about 1.5 seconds per lap or loosing all forward bite. Door open in just over an hour which should only have about an hour & half of practice. Can you say: Power Test?
Old 10-20-2007, 07:45 AM   #2340
protc3's Avatar
So the car starts to push off power and is loose on power? Hmm, I will PM you my home number. I will be leaving work in about an hour.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
