the kit does not include a bumper.i can talk to pdub and see if they would be interested in offering one for it though
That is what I put on the front of mine with some fun dremel flinging black powder action...LOL
Oh I can not wait to get the new rear pod so I can run real spur gears again...LOL
-Shookie <><
__________________ All who love the LORD JESUS I praise with you.1 Cor 10:31 Team HOLY Rollers (Team Manager) The Church is a Hospital for Sinners not a Museum for Saints. RcTech Feedback<><RC Tech Subcriber #92
Maybe a chance to see what the team drivers are running as far as setup..
Adrian, Jason, any other team guys...
Just wondering what setups are working where...
Asphalt and Carpet...
If that is alright with you guys...
Right now I am running High Bit Asphalt and wanted to know which tires are working...I have a few selections but here is what I am trying right now...
Front.
.20 springs
5000 wt on kingpins
10* caster blocks
Arms centered on blocks
Pink CRC pro cuts
Center
AE 30wt oil
copper spring
no shim under ball stud
Batteries Centered
Rear
Diff tight backed out 3/4 turn
5000wt on links
.75 L plates
Rear Pod level-.5mm droop
Double Pink CRC pro cuts
Am I missing anything???????????
-Shookie <><
Your running softer tires in the front then the rear?
Just using what was working for me on Carpet...
I have only had one day on Asphalt just asking questions...
I was goign to to go purple up front but wanted to get a few suggestions before I buy any more foams....Limited budget.
-Shookie <><
Personally if you were getting enough traction with the softer tire and 1/3rd to 1/2 traction compound coating I'd try a harder tire with a full width compound coating.
Front.
.20 springs
5000 wt on kingpins
10* caster blocks
Pink CRC pro cuts
Center
AE 30wt oil
copper spring
Batteries Centered
Rear
5000wt on links
.75 L plates
-Shookie <><
i run 2x pink in the front and rear on asphalt.i have never been a fan of the purple fronts.i am going to be trying the lilac fronts on my next outing.i think they are going to be real good.the rest of the setup looks good bro.the only other thing you should do is try a IRS medium ballstud for the shock mount on the antenna mount.i really liked the on power steering i gained from it.
Jason Breiner
BMI Racing
www.bmiracing.com
DB12RR lipo edition cars now available
We ( everyone ) run double pink in front and greys in the rear on asphalt at the C.
This is DICK!!! And you're NOT!
RC Tech member #11 ROAR Member 98196
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
