Old 10-11-2007, 04:15 PM   #2191
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by Diffdude View Post
Nova F1 Racer,
You are using to fine sandpaper. I recommend using 600 wet/dry only. You are actually making them so smooth they will not grip the diff balls. To get the diff locked you have to tighten the diff nut to much and risk damaging the balls or rings. Using the 600 only gives the diff balls something to grip so you don't have to over tighten the diff nut. The radius of a 1/8th diff ball cannot fell the scratches made by 600 grit sandpaper. A properly prepared diff will not slip but when the spur gear is held the wheels will spin freely in the opposit directions. Try it.
Dave "DiffDude" Irrgang
I've found that using a little less lube that the it grabs just fine and lasts a longer. The diff nut is snug, not over tighten.... And smooth...
BTW, the "special oil" I use is from an old machinest that gave me a gallon back in 1969..... It has mercury in it before it was outlawed... I've got less than a cup left....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 10-11-2007, 05:19 PM   #2192
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
Originally Posted by Casey View Post
set up talk here:
Ran it yesterday, pink rear , lilac front, 5 k lube in tubes, and kingpins, thick side plates, 4 mm front, 3.5 mm rear ride height, Parma speed 8 med grip carpet, 10.5 brushless geared at 59mm rollout, 2o frn spring, silver center shock, 1 deg camber, split spacer for castor. car was nice, consistent, seemed to push a bit mid cornor and off the corner,
Please share some setups so we can compare, I am only one so far in the area running it on carpet, Nova is runnin his on asphalt
btw cant slam the body too much with the BL motor tabs hittin the body
What up Casey? I will be at Mimi's this weekend with my DB12R as I am in the process of building it right now for Saturday. You gonna be there this weekend? Wade ordered a car too...don't think he will get it in time to build but it's quickly looking like 12th scale will be going strong this winter at Mimi's.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 10-11-2007, 05:30 PM   #2193
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Craig wasup bro,
Man wait till ya try this car, this car is the Killa on carpet and asphalt you will be very impressed.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-11-2007, 06:15 PM   #2194
robk's Avatar
Trader Rating: 22 (100%+)
As far as the center- out push, i have noticed a few guys have posted about it, and i have had some issues with it as well, especially in mod. I noticed moving the battery forward was a big help to me. If I remember right, I went 2 scew holes in the battery adjuster forward, more of a mid location than all the way forward.
I think having the weight over the front end more is a bigger advantage on power (at the end of a corner) than trying to get the car to pendulum with the weight in the back. Your mileage may vary
Also, to the BMi crew, thanks for getting my order out. I needed it for the weekend, and I got it today.
Old 10-11-2007, 06:21 PM   #2195
Casey's Avatar
hey Craig, going to Orlando in the morning, but i'll b back next week
Casey is offline   Reply With Quote
Old 10-11-2007, 06:23 PM   #2196
Casey's Avatar
thanks to all, i was trying to get everyone to post their set ups, and how they ran, cause when i go to another track, I may want a center offpush, I know how to do that now !!
Old 10-11-2007, 07:05 PM   #2197
xtrememadness's Avatar
Send a message via AIM to xtrememadness
casey you dont need no setups. you can drive the wheels off anything hey man have a good trip in orlando. cant wait to come down and ride. if my db12 shows up and i finish it in time i think we can squeeze some racin in too whats up craigx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 10-12-2007, 03:12 AM   #2198
protc3's Avatar
Casey,
Pretty much what everyone has posted already will help rid the car of the slight on power push. It is nice to have such a good group of people up here to help. There will be a decent amount of DB12R's at blue diamond running this weekend. Its gonna be nice to see all of you guys get to run them.
Craig,
Glad to see the car got there buddy. Let me know if you need anything
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-12-2007, 09:09 AM   #2199
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Just a quick read over this post, I agree with the bat placement. I am running on CRC Fast Track II with Jack and I am having some other issues that maybe can get a quick answer. I am getting some traction roll and 3 wheel action (lifting the front inside wheel) for the first minute and a half. I have the suggested yellow/lilac combo, fairly low tire at 1.75 & 1.65. Full sauce on the rear, 1/3 front. Kit set up with bat's centered, servo up in the mounts, 2mm spacer under the front center shock ball stud. Grip is slightly more then med. Tires seem to be the obvious answer which I have not tried yet. I could CA the front outside edge of the tire, but that seems a bit early in the learning of this car. The "power on" feels pretty good, quick transitions feel excellent, placement of the car on a less then smooth track, is excellent. High speed turn in at the center of the turn needs some work - the correct tires to free the car up from binding down too much - seems to be the direction I want to go. Any advice? Tires to try?
Brian: Slapmaster Tools
Slapmaster6000 is offline   Reply With Quote
Old 10-12-2007, 09:43 AM   #2200
protc3's Avatar
I would go to running the servo flat when the bite gets on the higher side.the bump toe in should relieve some of the excess steering and mellow the car out on entry. Maybe going to 6 degrees of caster also. 40 wt. oil may help quite a bit also to create a little more resistance in the shock helping to keep the car from rolling as much. I try not to glue tires unless it is 100% necesary. I also run my tires at 1.7 rear and 1.625 front for higher bite and a nice radius on the edge. Let me know how it goes. Give me a buzz when you are at the track running and we will get it going the way you like bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2007, 09:52 AM   #2201
robk's Avatar
I wouldn't be afraid of gluing the tires. You could also try moving some spacers from on top of the upper arm to the bottom. That might kill a bit of the roll over the nose. Also, how wide is your front end?
Old 10-12-2007, 09:52 AM   #2202
Uga
Uga's Avatar
huh, Jason would you mind coming to my track to help me getting the car dialed in? It's the other end of the world, but hey, it's still the same planet!
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-12-2007, 01:32 PM   #2203
Casey's Avatar
LOL !!
Santry, Hey glad to see you and the NYC boys are getting the car, told you it's nice !!
X-
run some yellow rears at Mimi's and let me know how they rotate the rear , and watch out for the bump in the sweeper !! stay close in on the boards
Jason, yes it is a good variety of people !! in a very short time we will have just about every track type and condition nailed down, and be able to pass the setup tips along to everyone !
Old 10-12-2007, 01:36 PM   #2204
protc3's Avatar
I will be glad to help but i hate flying
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-12-2007, 01:37 PM   #2205
protc3's Avatar
LOL !!
X-
Its gonna be a good year.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
