Old 10-10-2007, 09:48 PM   #2161
Scottrik's Avatar
Trader Rating: 245 (100%+)
The IRS Pivot Ball Insertion Tool IS worth it's weight in gold. Wouldn't build a car without one. Or a 1/8" reamer. Or...
Jason, ygpm
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-10-2007, 10:06 PM   #2162
Kail's Avatar
Thats the thing, I have no such tools! Worse still, I am in Canada now. Shipping a small part like that is crazy
Kail is offline   Reply With Quote
Old 10-11-2007, 02:01 AM   #2163
Jason,
You need to sort out a price for a pre-built car! Assemble the except the aerial and ship it in the same box, all we have to do is install electrics and we're off!
TraceRacing is offline   Reply With Quote
Old 10-11-2007, 03:14 AM   #2164
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by 1armed1 View Post
Kropy,
You going to Ft.Wayne sunday for the trophy race?
I'll be in Toledo for their first race if my speedo's show up by this weekend.
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-11-2007, 06:46 AM   #2165
Kropy,
IRS does not accept pay pal, sorry.
Dave
Diffdude is offline   Reply With Quote
Old 10-11-2007, 09:15 AM   #2166
MarkBrown's Avatar
Default diff ring coning
I'm slowly assembling my car, working on the diff rings now. (Skipped the shock, waiting for a replacement cap from DiffDude.)
What I notice as I sand the diff rings is that they are quite conical. On one side the sanding only scuffs near the center of the ring; on the other, only near the outer edge.
Is part of the reason for sanding the rings to make them flatter?
If so it would seem more effective to start with a coarser paper and finish with the #600, instead of trying to remove all that material with the #600.
--mark
MarkBrown is offline   Reply With Quote
Old 10-11-2007, 09:33 AM   #2167
mtveten's Avatar
Trader Rating: 27 (100%+)
--mark
Mark,
If one of your rings require a significant amount of sanding I would try another. I'll be at SIR on Sunday with spares if you need one.
Mark
mtveten is offline   Reply With Quote
Old 10-11-2007, 09:40 AM   #2168
protc3's Avatar
--mark
It is very common and this is why you want to sand them. The reason this happens is because during the stamping proccess,there will be some deformation. I am very surprised how minimal it is on the diff rings being that stampings usually deform so much that they need to be flattened. I would imagine that they are flattened after the stamping proccess but there will be a slight bit of memory in the material that will make it real hard to get them perfect. Try starting with 220 drit and then start going to finer paper as they flatten out.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-11-2007, 09:41 AM   #2169
MarkBrown's Avatar
Originally Posted by protc3 View Post
Did you guys ream out the front steering blocks after installing the front axles? If not this will tweak the car badly because the spindles need to move freely on the kingpin.
I have a question on this one. While building the front end I lacked an 1/8 inch reamer (Jason, you are missing a bet by not selling 1/8 inch reamers), so I went to SIR to borrow one. Fortunately for me, Brian Bodine was racing there that day, so not only was I able to borrow a reamer from him, I was able to get his advice on "blueprinting" the front end.
His first advice was to perform some extra trimming on the upper suspension ball ends, beyond the trimming called for in the DB12R instructions. He trimmed material from the outside top and from the inside (right next to the pivot ball) bottom. The inside bottom trimming prevents the steering block from contacting the ball end as car rolls and the spring compresses.
His second (and related) advice was *not* to ream the steering blocks so that they float on the kingpins. Just ream them enough for an easy press fit. The steering blocks don't need to float if the ball end is sufficiently trimmed, and you get less slop in the front end by not having them float.
Sounds to me like both techniques work, you just have to do a careful job on the front end whichever way you choose to do it. What do you think, Jason?
Old 10-11-2007, 10:08 AM   #2170
protc3's Avatar
Brian is correct. Normally i run a shim on top of the steering block. I do this for the same reason as brian trims the bottom of the eyelet. I ream the steering block so that is will slide on the kingpin but with no side slop. The reason i do this is because if you take a good hit and the kingpin shifts in the steering block, It will not be able to return and will give the car a tweaked feel. In theory, the only portion of the kingpin that needs to slide on the kingpin is the area through the lower arm. Unfortunately the AE design makes it so it needs to slide through the block,and both the upper and lower arm. I am working on an aftermarket kingpin and upper ball that will make things a whole lot easier.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-11-2007, 11:36 AM   #2171
protc3's Avatar
Too much info bro. Just make sure your speedo's are not to tight. I heard it can make you sterile.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-11-2007, 11:42 AM   #2172
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Diff rings, here is what I do.....
Take diff ring, start with 800 grade sandpaper... Yes a little 3-1 oil about 15 minutes each side
clean
then 1500 sandpaper... about 8-minutes per side
clean
Lastly 2000 grid very little oil...... about 5 minutes per side....
clean You can almost see yourself on them....
I use auto repair sandpaper..... Diffs last a long time......
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 10-11-2007, 11:44 AM   #2173
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
sounds like to much work! sanding them on teh sidewalk works to!!!
J, how close are you to being done with this tuning guide you were talking about..
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-11-2007, 11:44 AM   #2174
Maybell's Avatar
beautiful piece Jason! I got to race against a certain car maker that was running your car and it was pretty good! nice looking too!
good job man...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 10-11-2007, 12:20 PM   #2175
Nova F1 Racer,
You are using to fine sandpaper. I recommend using 600 wet/dry only. You are actually making them so smooth they will not grip the diff balls. To get the diff locked you have to tighten the diff nut to much and risk damaging the balls or rings. Using the 600 only gives the diff balls something to grip so you don't have to over tighten the diff nut. The radius of a 1/8th diff ball cannot fell the scratches made by 600 grit sandpaper. A properly prepared diff will not slip but when the spur gear is held the wheels will spin freely in the opposit directions. Try it.
Dave "DiffDude" Irrgang
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
