Old 10-04-2007, 02:15 AM   #2011
Trader Rating: 22 (100%+)
Originally Posted by BSchorr View Post
what do you mean rear holes in the chassis? i only have 1 hole for each screw..
It took Jason to notice it.
It will change your ackerman to much in the position that you have the servo mounts, try one screw only on each side from under the chassis.
The tie rods are better mounted more parallel.
Like this _ _
Or mount your ballstuds on the other side of the servo saver.
bjspinner is offline   Reply With Quote
Old 10-04-2007, 02:55 AM   #2012
Ben there should be 2 holes in the chassis for each servo mount for a total of 4 holes. Use the chassis holes more towards the back if you have the servo ballstuds facing forward. Look on the pic in step 12 of the manual to see a layout of those holes.
Sydewynder is offline   Reply With Quote
Old 10-04-2007, 03:06 AM   #2013
protc3's Avatar
there are 4 holes in the chassis. There are supposed to only be 1 screw in each mount. The forward holes in the chassis are for the balls behind the servo saver. Slide the mounts back to the rearward holes in the chassis and they will line up with the forward holes in the servo mounts.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-04-2007, 03:09 AM   #2014
protc3's Avatar
Originally Posted by Uga View Post
Just painted a body for the upcoming season, take a look
That is wild buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-04-2007, 04:37 AM   #2015
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
i see now, i jsut brainfarted, dam! i have to move my RX then! sucks
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-04-2007, 06:24 AM   #2016
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Ummmm You do realize that the car is sitting on top of your laptop... And if it has the motor in it you might want to not do that anymore... You see the motor has magnets in it and the hard drive really hates that.....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 10-04-2007, 08:14 AM   #2017
PW
PW's Avatar
Send a message via AIM to PW
I was thinking the same thing
PW is offline   Reply With Quote
Old 10-04-2007, 08:43 AM   #2018
protc3's Avatar
we are having a bunch of cumputer issues at the shop. Is that all it takes to wreck one? If so i am putting my whole motor case on mine. Hell, I may even hook the magnet zapper up to it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-04-2007, 10:56 AM   #2019
Uga
Uga's Avatar
Ummm, does it really have that serious effect? I mean there's a screen and all the plastics between... I really don't believe that any significant magnetic field is getting through all the way down to HDD.. But anyway, it was like 2 mins, while I took the photo (I was just sitting at the PC at the moment :P )
-=Xray XB4=-
-=Xray T4=-
-=Schumacher Cougar KF2=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-04-2007, 12:23 PM   #2020
See post... Yes they can...
RC Tech member #11
Old 10-04-2007, 12:28 PM   #2021
http://www.cknow.com/vtutor/HardwareThreats.html
Magnetic Zaps
Computer data is generally stored as a series of magnetic changes on disks. While hard disks are generally safe from most magnetic threats because they are encased within the computer compartment, floppy disks are highly vulnerable to magnets. The obvious threat would be to post a floppy disk to the refrigerator with a magnet; but there are many other, more subtle, threats.
Some of the more subtle sources of magnetism include:
Computer Monitor. Don't put floppy disks anywhere near the monitor; it generates a magnetic field.
Telephone. When ringing, telephones (particularly older phones with a bell) generate a magnetic field.
Bottom Desk Drawer. While the desk drawer does not generate a magnetic field, the vacuum cleaner that the maintenance people slide under the desk to clean the floor does.
Bottom Bookcase Shelf and File Cabinet Drawer. Same comment as the desk drawer just above.
Pets. Pet fur generates a strong electrostatic charge which, if discharged through a disk, can affect files on the disk. Instead of "The dog ate my homework," today it could just as easily be: "The cat sat on my homework." (I once had a student where this exact problem happened; a cat sat on her floppy disk and static wiped out the data on the disk.)
RC Tech member #11
Old 10-04-2007, 12:47 PM   #2022
theisgroup's Avatar
Magnetic Zaps
this is not very likely. just sit a motor on top of a floppy for even a day and see if the floppy still works. I guarantee you that it will have no effect. we use a high power electromagnet that spins to even clear backup tapes. to clear a hard drive we have to run this thing for like almost 1 hour.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-04-2007, 01:19 PM   #2023
Kropy's Avatar
Send a message via AIM to Kropy
Are we still talking about cars?........LOL
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-04-2007, 02:29 PM   #2024
wallyedmonds's Avatar
lap top
motor on it
HD gone
dont do it again
lap top on speaker
HD gone
wallyedmonds is offline   Reply With Quote
Old 10-04-2007, 02:58 PM   #2025
BSchorr's Avatar
J, the goods arrived, first thing i did was make sure te shock cap works! Just intime to run this weekend.
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
