Old 09-30-2007, 06:55 AM   #1876
Trader Rating: 23 (100%+)
Any DB12R's make the feature in Vegas this week end?
SteveL is offline   Reply With Quote
Old 09-30-2007, 07:17 AM   #1877
protc3's Avatar
Im not sure. We were not pushing for this race because it was too close to the release date. We will be building a strong team for the snowbirds. We needed the time to get the team more familiar with the car. Come snowbirds time, You will be seeing some results.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-30-2007, 07:52 AM   #1878
ttso's Avatar
Too bad Snowbird is on opposite surface of Earth (means 20+hrs flight time), otherwise I would love to attend..
ttso is offline   Reply With Quote
Old 09-30-2007, 09:39 AM   #1879
protc3's Avatar
Not a problem buddy. We have what i believe is the best car. Now i just need to get it in the hands of the best drivers so i can prove it.
Alot of the cars out there do well at the big races because of who is wheeling the car. Once we accomplish that, The competition is in deep trouble. I am working on making this happen
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 09:39 AM   #1880
Kropy's Avatar
Send a message via AIM to Kropy
J ~ How do you like that Pitboard
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 09-30-2007, 09:40 AM   #1881
ttso's Avatar
Here is my car. Jason feel free to use it on website..
I know someone probably ask, the bumper is from Kawada which I knife it down a little bit and drill new mount holes, the ESC is GM SX9 with Novak transcap behind.
Old 09-30-2007, 09:44 AM   #1882
protc3's Avatar
that is trick bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 09:44 AM   #1883
protc3's Avatar
email your pic to adrian with your name and we will get the pic on the site
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 10:42 AM   #1884
protc3's Avatar
Hey guys,
I forgot to tell you,the new front ride height adjusters are in stock and ready for shipment. The rear axle shims will be in stock on tuesday. These are the shims that will eliminate the need for washers on the axle. 1 on each side will bring you right to 172mm. They will be high finish aluminum spacers. It will give you the bling without the agrivating task of setting the track width and centering the axle. Now it will be done without any thinking
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 11:03 AM   #1885
radio_car_racer's Avatar
Originally Posted by radio_car_racer View Post
Jason,
Ran the car on Tuesday night after Sunday’s race when I ran the FF’07 DB12R not ready.
This was done after the carpet had aired for 2 days and was the same layout.
Only had two runs using same motor (unskimmed) & tyre type and,
Single lap faster by 1.17s
Average lap down by 1.057s
Unbelievable the way the car corners with speed.
Only place I seemed to struggle was in the switch backs (left/right/left) were the car was to responsive. Maybe addy & or servo KO949. (Usually run a Sanwa 141)
Tried the olive spring to gain a bit more rear end.
Car seemed to be skipping a lot under power on the rear.
Body: Hot Bodies Ferrari (used as I like it and didn’t have a Parma ready)
Tire Compounds: BRM Purple/Grey = f 44mm r52mm
CS High Grip Tyre Additive : Full front & Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 10* Block
Caster: Middle
Camber: set to run foams square
Ride Height: 3.5mm
Toe: zero
Front Track: no shims on axles
Front Spring: .020”
Front Preload/Droop: No Preload/very little
King Pin Damping: none (don’t like to do it)
Servo Mounting: Angled
Shock Length/Pod Droop: 2.6” (66mm)/.060 (1.5mm)
Shock Angle: Med IRS ball stud on AE Ant-Shock mount
Shock Spring: AE gold / AE Olive
Shock Oil: 35wt
Side Damper Oil: 100wt shock oil (no heavier oils)
Flex Plates: .070”
Flex plate preload screws: Not installed
Rear Body Mounts: To the rear
Rear Track: 172mm
Track Layout
UPDATE
ran the following today on same track layout today and best lap of 14.73s with the setup edited in blue below,
Tire Compounds: GRP Magenta F&R = f 44mm r50mm
CS High Grip Tyre Additive : 3/4 front & Full Rear (like to do full front to help keep tyre wear even)
Reactive Caster: 5* Block
Caster: Middle
Ride Height: 3.5mm
Toe: zero
Front Spring: .020”
Shock Spring: AE Blue
Shock Oil: 35wt
Side Damper Oil: Medium Corally Damper Syrup
Flex Plates: .066” thin
Rear Track: 172mm
Motor: 19t BRM XXX brush +&- 42.8mmpr same as last time but not shown
radio_car_racer is offline   Reply With Quote
Old 09-30-2007, 11:14 AM   #1886
protc3's Avatar
Thanks for the feedback buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 11:21 AM   #1887
No Probs.
PM on it's way re the above setup
Roll on the next UK national in October If it goes as well as today just may make my 1st * final, prediction deleted as it won't happed
Old 09-30-2007, 11:24 AM   #1888
protc3's Avatar
good luck buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-30-2007, 11:42 AM   #1889
UPDATE
Quickest lap by a brushless was 14.39s and this guy makes the A @ the UK nationals, got the proof as he ran my PT in his car. Another brushless turned a 14.62s lap I recall. (Both running the V-Design chassis)
I was running 19t brushed so well please with lap time v the brushless motors
Old 09-30-2007, 11:54 AM   #1890
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Anyone have pics of this car with a lipo in it?
Is there even a lipo that fits?
Lipos are legal at bolth my tracks, so im going all lipo FINIALLY
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
