Old 09-29-2007, 08:54 AM   #1846
Jason,
Mike I. and Mike M. will be running their cars tonight. They are very happy with the build of their cars and I'm sure they will lower the track record with them. I wish I could be there but I have to leave for a race in Maryland this afternoon.
Dave
Diffdude is offline   Reply With Quote
Old 09-29-2007, 09:28 AM   #1847
wallyedmonds's Avatar
how do you do tweak on this car.
wallyedmonds is offline   Reply With Quote
Old 09-29-2007, 11:06 AM   #1848
protc3's Avatar
Originally Posted by Diffdude View Post
Jason,
Dave
Cool deal dave. Have fun in maryland bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-29-2007, 11:07 AM   #1849
protc3's Avatar
There is no tweak to set. The only things that tweak the car is a broken part or collapsed front spring. The car is designed to self allign and it doesnt get knocked out of adjustment.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-29-2007, 11:38 AM   #1850
ttso's Avatar
While my car is quite tuned, I do still have a small problem on handeling.
In 1 or 2 corner, which is right after short straight which I apply full throttle less than a sec and brake right away, the front of car looks like turn-stuck-turn-stuck before it hit apex. If I leave the throttle earlier, don't apply brake but let the car free roll into corner, no such problem, but slower.
I recall Adrian or Jason explain the physics about it but I can't find it anymore. I think it's something to do with too much weight transfer to front causing front refuse to roll, but I'm not sure as I can't find the post. How should I change setting to fix the problem? Less rear droop to limit weight transfer?
Thanks.
ttso is offline   Reply With Quote
Old 09-29-2007, 11:44 AM   #1851
protc3's Avatar
is this on carpet or asphalt?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-29-2007, 12:07 PM   #1852
ttso's Avatar
Carpet 19T, front 1.7 double pink, real 1.8 pink, spring front 0.020 rear CRC-gold
Old 09-29-2007, 01:02 PM   #1853
protc3's Avatar
which lube do you have in the damper tubes and on the kingpins?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-29-2007, 01:13 PM   #1854
RichChang's Avatar
Hi Jason - how did you guys get a servo that is laid flat to fit behind the right suspension arm? I am running into a problem with the servo ear behind the right side suspendsion arm. It looks like I will need to dremel quite a bit of the lower suspension arm to get it to clear the screw holding the servo ear in place?
Previous 1/12th's I shoo goo'd the servo in place but I'm trying to stay with your awesome servo mounts.
Thanks!
-Rich
RichChang is offline   Reply With Quote
Old 09-29-2007, 02:17 PM   #1855
protc3's Avatar
I only use 1 screw on each servo mount to hold the mounts to the chassis. The rearward set of holes is for mounting the servo flat. You will need to run the ballstud on the front of the servo saver for this. I use the middle hole on the servo saver and medium ball studs on the spindles to take alot of the bump toe in out of the geometry.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-29-2007, 02:22 PM   #1856
protc3's Avatar
oh yeah,you will also be using the forward mounting hole in the servo mounts. I just finished mounting my electronics on my mod carpet car with the servo flat. There is a ton of room behind the arm with it like this and the geometry is just right
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-29-2007, 03:05 PM   #1857
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by mike ivy View Post
Hey Guy's check it out my new hotness, gotter done a few day's ago cant wait to rip on some 1/12th scale
SWEET!
Looks awsome man!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-29-2007, 03:18 PM   #1858
RichChang's Avatar
Hi Jason,
Ah! That explains that. Thanks!
-Rich
Old 09-29-2007, 05:51 PM   #1859
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by RichChang View Post
Hi Jason,
-Rich
Rookie....
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 09-29-2007, 06:26 PM   #1860
redlion's Avatar
Jason you have PM.
Wes
redlion is offline   Reply With Quote
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
