Old 09-24-2007, 08:18 PM   #1726
ChestyV32's Avatar
Trader Rating: 32 (100%+)
its not my clothes its all the RC stuff, damn the RC stuff LOL
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 09-24-2007, 08:25 PM   #1727
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-24-2007, 08:48 PM   #1728
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Randy Caster View Post
If I'm not mistaken any Orion drivers running 1/12 at the IIC will be using Vortex brushless motors rather than V2's.
Awsome!
I will have to watch that.... I use there 10.5 in my TC.....
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-24-2007, 10:47 PM   #1729
ttso's Avatar
Found an useful page on PetitRC, sheet for foam tires..
http://www.petitrc.com/_forumphp/sho...d.php?p=254062
ttso is offline   Reply With Quote
Old 09-24-2007, 11:16 PM   #1730
Scottrik's Avatar
Trader Rating: 240 (100%+)
Originally Posted by mxracer23 View Post
2. Measured the front lower arms, they both are within 0.013 of each other in height
I can't seem to figure it out, I am alittle less than 0.5mm out from right to left.
Originally Posted by protc3 View Post
Here is your answer. .020 is .5mm .013 is real close to that. You need to check and make sure that there is no burrs on the arms. Maybe even sand them lightly on a flat surface to remove the high spots.
I ran into the same problem last fall setting up three new cars all with IRS lowered Associated arms. They were all off by about .015. No obvious burrs, etc. I was very surprised by this as I'd been fat dumb and happy (like always) figuring they'd be square since they're milled...I'm sure in a fixture of some sort.
Another thing that's come up...I started getting about a .5mm difference in height side-to-side. Measured springs, etc, re-set spacers, etc. Finally figured out that my pivot balls (always Niftech polished bronze) are floating up and down in the lower arm. No doubt an impact (impacts) have enlarged the socket.
I'm really wanting to try the new IRS lower arms. Also really wanting to try a Laje SpeedEvil front end but they're out of a couple key parts. He'd also not thought of drilling the new IRS arms for his front end when I asked if this was available (and he's a IRS dealer/importer).
Looks like the DB12R will have great success Jason. I was interested to see someone describe it as, basically, the missing link between T-bar and link cars. That was what it looked like to me too. I may have to try one...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 09-24-2007, 11:30 PM   #1731
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Hey randy,
I sent a bunch of spares and parts for fine tuning the car. Give me a buzz if you have any questions bro.
Sweet, thanks Jason, I'll let you know if I need any help, if the car is as good as it was a couple weeks ago I should be fine!
Old 09-25-2007, 12:25 AM   #1732
Tron 101's Avatar
Trader Rating: 23 (96%+)
Exclamation ChestyV32
If anyone can get in touch with ChestyV32 by phone, by e-mail, I don't care let him know that the HARA 2.2 buyer doesn't have his PAYPAL address. If anyone can help me out I'm positive he'll thank you for it. Thanks in advance.
PM me with any info Cheers.
Good luck to all the racers in Vegas.
Tron 101 is offline   Reply With Quote
Old 09-25-2007, 04:17 AM   #1733
protc3's Avatar
I havent had issues with IRS's new molded arms. I did have alot of issues with the AE ones but these seemed to be real accurate so far. Anything is possible though Thanks for the props on the car dude. Looks like we need to get you into one soon.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-25-2007, 04:19 AM   #1734
protc3's Avatar
Try calling Fast track hobbies. He works there. He is leaving for vegas today but i am sure one of the guys at the hobby shop can help you
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-25-2007, 04:43 AM   #1735
The Laje is basically a modified version of the original Trinity front end. Modified to use a 3rd link for camber adjustment. A nice idea which really makes it easier to adjust but makes for a heavier and less attractive front end. The good part as applies to this conversation is the lower arms were 1 piece graphite plate and had no lower pivot ball making left to right ride height more accurate then a pivot ball lower. But once the lower kingpin hole starts to elongate then you start having differences in caster and camber from left to right. In the original 1/10th scale version the front end would work better with a bit of slop in it then it did tight. 1/12th being a bit more precise I'm not sure it would work as well. The best front end idea I've seen yet was a Trinity varient that I believe only lasted for 1 model. It was the EV10/Revolver 12 style lower plate but used AE style upper arms. The original link style upper arm did not give enough steering throw with off-set axles on my Revolver 12 because of how wide the top pivot piece was. But with a single rod end like the AE or Laje upper arms should have plenty of steering throw. If I had my own machine shop I'd make my own front ends with a graphite lower plate and AE upper arms.
Old 09-25-2007, 06:55 AM   #1736
mxracer23's Avatar
Wow thanks everyone, It looks like everyone is in agreement here. So I took a little material off the right front lower arm to get them the same and then I re-attached the U-Plates making sure that the car was on a flat surface with just enough sticking off to get the screw in. It got the car level and took out the twist and the bad tweek that it had before.
Can't wait to get it out on the track!
Mark
mxracer23 is offline   Reply With Quote
Old 09-25-2007, 07:00 AM   #1737
protc3's Avatar
Im glad it fixed the issue you were having. There is a possibility for variation in molded parts.the IRS arms have all been real accurate but im sure that there can always be that odd one here and there. Let me know if you have any other questions or need help with anything else.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-25-2007, 07:08 AM   #1738
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Mark
Alrighty then, now get out and RACE!!!!!!!!!!!!!!!!!!
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-25-2007, 10:37 AM   #1739
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-25-2007, 10:51 AM   #1740
Off to Vegas!
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 05:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 10:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 06:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 04:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 07:25 PM
SEO by vBSEO 3.5.0
