Old 09-24-2007, 10:15 AM   #1711
mxracer23's Avatar
Thanks Guys,
Nova:
Where are you measuring the ride height? Front or rear sides?
I measured from the sides from the front of the chassis to the split by the pod.
Are the flex plates the same in the rear?
I put in what came with the kit I will measure them to make sure that they are the same
Ride height spacers, are they the same?
Same thing here what was included in the kit I am using both the thick and thin spacer in the front both sides are the set up the same
Measure from the hole in front of the car to the wheelas and see if they are the same....
Help me here are you talking about the center balance hole, Checking for width?
RobK
I didn't check the springs after I put them in only before. They measure the same on my calipers but I didnít look at them after I installed them. Maybe they are sitting on the pivot ball wrong or collapsed
When I get home tonight I will have to give the car another looking over.
mxracer23 is offline   Reply With Quote
Old 09-24-2007, 10:23 AM   #1712
redlion's Avatar
I'm not going to say a WORD about it... And I expect more from you!!!
Will do captain will do. Most certainly. Appreciate all the help.
Wes
redlion is offline   Reply With Quote
Old 09-24-2007, 10:39 AM   #1713
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by mxracer23 View Post
Thanks Guys,
Nova:
RobK
Yes, the track width....
Check the rear pod droop to see if they are the same..
The springs have already been mention... Have to tried the quarter balancing test on the front?
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-24-2007, 01:30 PM   #1714
protc3's Avatar
Thanks Guys,
Nova:
RobK
There are a few things you can check. Make sure that the pivot balls are fully seated and that the flange on both sides are facing the same direction. There may also be a slight variation in the springs that allow 1 to sag more than the other. Other than that,it may be that the balance is off on the car. You want the electronics to balance the car. If the car is not balanced it will sag one side more than the other. Let me know how it goes.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 09-24-2007, 01:34 PM   #1715
The pivot balls... I should have thought of that....
Remember Racers, always check that your balls are fully seated in the right direction before using them...
Can't wait to see that in the owners manual....
RC Tech member #11
Old 09-24-2007, 03:18 PM   #1716
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
LOL!
Nice
J, your using the spektrum micro RX correct?
I am going to run the same electronics, well and a orion 10.5 (not finial on that)
Any recommendations for a 10.5? I dont want the novak...
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-24-2007, 04:34 PM   #1717
protc3's Avatar
The only 10.5 i have run so far is the novak 10.5. I really liked it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-24-2007, 04:51 PM   #1718
protc3's Avatar
2. Measured the front lower arms, they both are within 0.013 of each other in height
Here is your answer. .020 is .5mm .013 is real close to that. You need to check and make sure that there is no burrs on the arms. Maybe even sand them lightly on a flat surface to remove the high spots.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-24-2007, 04:54 PM   #1719
RichChang's Avatar
I also recommend measuring the distance from the bottom king-pin e-clip to the bottom of the lower arm. That will indicate if something is bound up (such as the king-pin in steering knuckle if it is not free moving). Also, the top suspension pivot can get rotated when setting camber and cause the king-pin to lift, which causes the suspension spring to compress.
-Rich
RichChang is offline   Reply With Quote
Old 09-24-2007, 05:15 PM   #1720
protc3's Avatar
very true
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-24-2007, 05:21 PM   #1721
No novak for me.......
I dont like novak stuff.... LRP or orion for me, but the only person I have seen with a orion in there 12th is Andy Moore.... Which makes me wonder......
Pm on its way J
Old 09-24-2007, 06:14 PM   #1722
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Pm on its way J
If I'm not mistaken any Orion drivers running 1/12 at the IIC will be using Vortex brushless motors rather than V2's.
Old 09-24-2007, 06:58 PM   #1723
protc3's Avatar
Hey randy,
I sent a bunch of spares and parts for fine tuning the car. Give me a buzz if you have any questions bro.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 09-24-2007, 07:07 PM   #1724
ChestyV32's Avatar
Trader Rating: 32 (100%+)
I HATE PACKING
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 09-24-2007, 07:12 PM   #1725
protc3's Avatar
Originally Posted by ChestyV32 View Post
I HATE PACKING
hell, just wear the same clothes all week.
Jason Breiner
BMI Racing
Team Associated
J Concepts
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
