Old 07-20-2007, 05:55 AM   #1
razzor's Avatar
Default Diff assemble tips for Brushless.
I will be getting into the modified class and be using 3.5/4.5 brushless.
What or are there any good tips for building diffs for this application.
Ive read about guys burning out diffs and dont want to go down this road.
I am running a TOP Racing Scythe which i believe uses Yokomo diffs.
I am sure it would help a lot of guys who are getting into or running this class.
Thanks in advance.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-20-2007, 06:24 AM   #2
Send a message via AIM to canto54
If you are using the plastic outdrives, you should rebuild your diff every4/5 packs. I only burn one diff with plastic outdrives and this is because I don't rebuilt it between 2 sessions.
It would be better to use aluminium outdrives.
Other very important thing is to use the good grease. I always use AE Black grease in the thrust bearing and AE white grease (ref 6591) in the diff ring and balls and spur.
Other tip, after rebuildinfg your diff put it on the car then, use a motor master with brushed motor on the car or just a little throttle for 1minute and block one wheel by hand. after , adjust the diff and it would be fine
canto54 is offline   Reply With Quote
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
brushless tuning tips newbie2 Electric Off-Road 9 09-12-2008 05:58 AM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 08:22 PM
Help with set up and Assemble XXX-T MF2 Mr.Amorris Electric Off-Road 4 05-03-2007 03:31 PM
Favorite Diff Building Tips CRASH Electric On-Road 3 11-26-2003 09:03 AM
SEO by vBSEO 3.5.0
