Old 04-29-2003, 11:44 AM   #1
doublest's Avatar
Send a message via MSN to doublest
Default Needing help in sortin gear ratio of 6!
I have a gearing ratio of 7.8 at moment but have been told by my track racers that i need to have a ratio of around 6. I have been given a chart with my car. Can u help me pick the right spur and pinion.
Chart is included
doublest is offline   Reply With Quote
Old 04-29-2003, 12:24 PM   #2
CGR's Avatar
try this site.
CGR is offline   Reply With Quote
Old 04-30-2003, 07:58 AM   #3
sosidge's Avatar
What you've been given there is a gear compatability chart (i.e. what gears will actually a fit), rather than a gear ratio chart.
Your TC comes with a 78 spur, right? the other figure you need to know is the internal ratio of 2.2:1
So, from the gear ratio formula (which I'm sure someone has posted for you before)....
6 = (78 spur/? pinion)x2.2
or ? pinion = (78x2.2)/6 = 28.6
So a 28 or 29 pinion will give roughly the ratio you want.
Gear Ratio maximuspowell Nitro Off-Road 4 08-22-2008 04:17 PM
Gear Ratio ww racing Rookie Zone 3 06-22-2007 01:56 AM
gear ratio PoLsKiE Electric On-Road 4 01-17-2007 03:42 PM
Gear Ratio chaihot5 Singapore R/C Racers 14 10-01-2002 11:16 PM
SEO by vBSEO 3.5.0
