Old 07-18-2007, 11:08 AM   #1
VintageCars's Avatar
How powerful motor can I use?
Hi folks,
This is probably a stupid question among you guys who`s been in the game longer then me, but anyway, here goes:
I`ve got an 6 year old electric touring car with an electric Futaba MC 210CB speed controller, and I`m looking to make this car as fast as possible (arent we all....) without changing this speed controller. At the moment I`m running a 21T motor, but what is the limit with a speed controller like this? I`ve seen motors down to 7T double, but I have a feeling that a motor like that would kill this speed controller? Or can I shove any engine in there and just drive?
Thanks for answers,
VintageCars is offline   Reply With Quote
Old 07-18-2007, 11:46 AM   #2
CCristo's Avatar
Trader Rating: 54 (100%+)
According to this page you can go down to a 14 turn.
CCristo is offline   Reply With Quote
Old 07-18-2007, 01:56 PM   #3
Thanks for your reply! Do you know if this is only single engines, or can I also use 14T double as I`ve seen there`s most of? And also, I`ve seen 14t Modified.... What`s this, and can I use this?
Old 07-18-2007, 02:20 PM   #4
pyro18t's Avatar
OK...they are motors, not engines.
Second I don't think that I would go any lower than a 15T. Even if the ESC is rated for a 14T the amps that the new batteries and motors put out, you will probably cook the ESC
ESC= electronic speed control
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 07-18-2007, 02:50 PM   #5
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
It is not always advisable to go to a lower turn motor than its recommendations. Sometimes it is the heat that the ESC can handle rather than the turn limit.
Many years ago I use to run a Tekin Rebel 1st generation rated down to a 10T motor. It handled a 14T well but would get hot. It always thermaled with the 10T. I put a smaller pinion on the motor and was able to run the ESC with the 14T and it stayed cool that way. I then tried the 10T and it helped but still shut down at times. After a while I just left the 14T on it. I've known that guys have run lower turn motors but gear for torque to keep the motor cool. Thier car was slower than with the recommended motor.
I think your ESC, the 210 series is rated at 20T. The 310 series should be the one for 13T or more turns.
Hope this helps.
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
Thanks to the SoCal guys that help me & "Tha Man" Paul Lemieux
Racing TC Class where allowed with what I have.
F. Mendoza is offline   Reply With Quote
Old 07-19-2007, 11:23 AM   #6
wog....supraman's Avatar
Send a message via MSN to wog....supraman
i got a MC330cr and it is rated to 14t....i got this awesome 15x2 motor and the ESC would get soooooo hot.....and i would be crawling around....like 5%throttle....one of the guys at a hobby shop down here said "always leave at least a 1 turn margine" so i did, but with little progress......so i put the 330 aside n went and got my self a IPC 7.1 awesome speedie....no motor limit....got it cheap aswell.....
i say just get a better speedie coz u will get hookd in this hobby and ull want better and fasta...sooo get the good stuff early.
wog....supraman is offline   Reply With Quote
Most Powerful Brushed Motor george_georgoul Electric On-Road 4 10-16-2007 03:19 PM
Which is more powerful-.15 or .12? macnkitty2002 Onroad Nitro Engine Zone 4 07-11-2004 09:20 PM
most powerful EP motor no1 Singapore R/C Racers 14 05-18-2004 06:35 PM
tHE MOST POWERFUL .12 OUT THERE Dust Nitro On-Road 14 07-09-2003 05:48 AM
witch is a more powerful motor SuperRooster Electric On-Road 4 12-29-2002 11:01 AM
SEO by vBSEO 3.5.0
