Old 07-13-2007, 03:41 PM   #1
Trader Rating: 2 (75%+)
Battery for dummies
hi guys im just starting in this hobby is there a website or any information i could go to find the settings for my battery and charger? what is MV? BATTERY THRESHOLD? HOW MANY AMPS TO DISCHARGE, DISCHARGE RATE, HOW MANY AMPS WILL I LEAVE IN THE BATTERY? i need all the info i can get please help. by the way im using 2400 nicad, 3000 hi-mh, 4200 ni-mh. my carger is novak millenium pro, muchmore silent charger, ce-35gfx. thanks
cox is offline   Reply With Quote
Old 07-13-2007, 07:26 PM   #2
chris moore's Avatar
Trader Rating: 85 (99%+)
Well the first thing to do is trash the 2400's, those are hopelessly outdated and not even good to use for practice. The 3000's are only bairly good enough for practice and you would'nt want to use them in a race.
Most peeps charge at 5 or 6 amps, check the CE website and print a downloadable user manual for your gfx. Its a very good mutiuse charger and will do everything you need for ni-mh. If your batts have the labels on them use the same discharge rate that the battery reseller used, usually 30 or 35 amps.
Also its a good idea to use an equalizing tray after you discharge, that way you get a more even and full charge.
chris moore is offline   Reply With Quote
Set ups for Dummies sosidge Electric On-Road 2 11-21-2007 09:54 AM
Battery thread for dummies... Johnathan Rookie Zone 12 08-10-2006 10:29 PM
tc4 for dummies bignotch Rookie Zone 2 01-25-2006 03:07 PM
gearing for dummies pls help cox Electric On-Road 5 08-27-2003 08:16 PM
Porting For Dummies 101 shortyboy Nitro On-Road 5 06-24-2003 05:27 PM
SEO by vBSEO 3.5.0
