3 pin Deans for easy switching from brushless to brushed.
I called up Deans to see if they had plans for making a 3 pin Ultra connector. Although he was not allowed to disclose any details, it sounded like it was coming soon. A Deans 3 pin (pole) Ultra connector would be perfect for switching from brushed to brushless while still staying compatible with all of my gear and my friend's gear.
So, in the meantime, I made my own connector with some superglue and a dremel.
Here is my setup with a Brushless motor:
And here is my setup with a Brushed motor:
I'm not sure about the Novak GTB, but for the LRP Sphere, all you have to do for a brushed motor is combine the blue and yellow wires. From one of the male Deans connectors I disassembled, I used a spare connector to short the blue and yellow wires:
This could also be done with wire.
I'm really happy with the results. The superglue holds extremely well, and now I can easily interchange my brushed and brushless motors with my new Sphere. Additionally, the 3rd connector on the brushed motors does not interfere when I use a brushed speed controller that only 2 connectors. I'm looking forward to when Deans releases their 3 pin version of the Ultra connector.
I did the same thing to my Novak GTB and it works great!
Nice little innovation!!!
Very cool. Deans might just use yours as a prototype for their new connector.
That is a great idea. Glad I found this post I was going to do something like that......saves me using my brain to figure out how I was going to do it with deans ends. LOL
I don't know the brand but a friend of mine uses some low profile gold palted "bullet connectors to similar effect. He has no polarization though.
I've seen Novak's version of the brushed wiring and somehow it seems that you need all three wires on won of the negative pole and the positive direct. It's wierd.
Am I crazy or is this setup impossible? Wired this way there is a positive lead going to both poles on the motor.
Wow, that requires an extra wire compared to the Sphere. As seen by the above picture, the Sphere brushed setup is easier and cleaner.
i just got me a Novak GTB and 5.5 - i am wanting to use my GTB for my brushed motors as well - but it seems like it is going to be a major pain to use this ESC for both - you have to solder 3 wires on the negative tab of the motor -
anyone else with GTB figure out an easier setup for both brushed and brushless...
Mr. McGoo i just got me a Novak GTB and 5.5 - i am wanting to use my GTB for my brushed motors as well - but it seems like it is going to be a major pain to use this ESC for both - you have to solder 3 wires on the negative tab of the motor -
For brushed, why does it need all 3?
Alot of people are asking about wiring up their GTB and LRP brushless speedys so i thoguth i would bump up this thread.
Jamie
Jamie
I haven't used these yet but they look promising for this application.
http://www2.towerhobbies.com/cgi-bin...?&I=LXHEB5&P=7
