Old 07-08-2007, 09:55 AM   #1
Default Ce t35 outdated?
Does this older charger have a limit on mahr -mwhr Ihave noticed my 4200s are only charging to 3800 or so even though they peak around 6.00 on a four cell pack and are the right temp? Can some one share some imformation on this thanks.
impdog is offline   Reply With Quote
Old 07-08-2007, 08:05 PM   #2
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
The turbo 35 from competition electrics is far from being outdated.
The crew at CE revise the software and have updates... they are even close to an update that will allow the 35 to charge lipos.
If your not getting a full charge , feel free to call CE and talk with Jim. Maybe you have your charger incorrectly set. And if your running IB 4200 you might have a dead cell or your packs just might not be in as good a shape as you think they are..
CE is the most customer friendly company you are going to find in rc. They are great people and are always improving on there equipment.
wallstreet is offline   Reply With Quote
Old 07-08-2007, 08:17 PM   #3
Joel Lagace's Avatar
some older T35's needed a updated chip. I got mine in the mail and simply flipped the chip. If i recall it had something to do with the higher capacity and voltage cells... Anyway contact CE
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
Old 07-08-2007, 08:24 PM   #4
Default 35's
I know this is a little off topic but any chance of CE coming out with a new charger that may be a little smaller in size?? I've always wanted to get a GFX but the damn things are the size of Texas
_pilot_ is offline   Reply With Quote
Old 07-09-2007, 06:00 PM   #5
I should have said t35 Bl not gfx, called ce today and got v7 software upgrade for it for 25 bucks they send it to you and you install it yourself should be great.
Old 07-09-2007, 06:10 PM   #6
dsrbltoys's Avatar
Main problem, and what the update helped with was for cycling. After charging the battery, the voltage would hold higher than a value programed in the chip. That has been altered, and works great now.
As for under charging, I would double check the cells. Have they been equalized? Are the settings in the t35 set correctly? I use .02 - .03 drop back if over 5.5 amp. and .04 if 5.5 amp. Do they take a full charge on another charger?
Good luck
dsrbltoys is offline   Reply With Quote
Old 07-09-2007, 06:24 PM   #7
I think that the latest software version for the T-35 is version 5.70. Check you screen when you power up the unit.
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
TC4 outdated? ausman123 Electric On-Road 24 04-21-2008 08:32 AM
mtx3 outdated? chrisw Nitro On-Road 22 03-26-2006 09:33 PM
SEO by vBSEO 3.5.0
