Team Orion Vortex Brushless motor
#646
so what would you recomend me to get , 3.5 new version or 3.5 old version.
But if it has litle less torque does it mean i have to have a smaller pinion gear.And how many more rpm does it have.Finally how many more minutes runtime does it have with the same bateries and same electronic but just the newer or older motor as you said less cumsomption.
Thanks guys
Thanks guys
#647
Im purchasing a new vortex motor anyway, so i just wanna find out for myself if the new vortex rotor is a direct fit into the old vortex motor. I dont see a problem with it, apart from being a little shorter than the older version. rotor shaft should fit straight through the front endbell hole with ease, if not i can just drill the hole bigger. Unsure about the rear bearing housing though, whether the shaft will fit through that or not...
#648
wich 3.5 vortex is better, wich one would you guys recomend me :
http://cgi.ebay.co.uk/TEAM-ORION-VOR...d=p3286.c0.m14
OR
http://cgi.ebay.co.uk/ORION-Vortex-3...d=p3286.c0.m14
the one above but in 3.5 instead of 3.0.
OR
#649
Today tested 4 armatures ,
4 pcs same had bester than STD armature !!
STD not have torque had more rpm,
but changed type 1 & 2 RPM type , turn armature had get magnet feel like high turn brushed motor feel .
& tested in big track can gear up same with torque !
after tested Torque type 3 & 4 , same bester than std armature,
the punch feel is very direct !
#650
sorry if this was asked before but is 150 to 160 deg F a safe temp range for the 1st gen orion vortex 4.5 brushless motor? i ran several 7 minute offroad practice sessions with my durga. do i need a cooling fan for the motor? my mamba max esc was also in the 150 to 160 deg F range. the buggy ran fine throughout the day, but i really dont know what temp range i should be looking at when using this motor. thanks in advance for any info
#651
not an expert
#653
#654
thanks for the replies re. motor temp
#656
is there any list of percentage of gears for team orion vortex motor
#657
#658
http://www.roarracing.com/approvals/brushlessmotors.php
#659
Hi guys, with regards to changing armature, is there a way to make sure that the can is sealed back perfectly after you change armature and that there will be no binding? I have heard from friends that they have problem reassembling the motor properly and that after reasssembly, the motor just feels weird.
#660
just be cautious, the endbells are alloy (correct me if wrong). if your getting a bearing out, after each tap check the endbell hasnt bent or flexed. Ive taken my vortex apart numerous times, not once has it 'just feels wierd' afterwards. If your worried, you could always apply some blue loctite to the endbell screws, & make sure the armature is shimmed correctly, the first time you take it apart, note where what shim goes where!
