Old 04-22-2003, 03:00 AM   #1
Registered User
414mII: spacer on suspension arm block
414mII and Evo3 both use spacer between suspension arm block and lower chassis. What is the purpose and the difference seing different size of spacer?
Aku-Man is offline   Reply With Quote
Old 04-22-2003, 03:17 AM   #2
davioh's Avatar
i think it makes the chassi lower (with more spacers)
davioh is offline   Reply With Quote
Old 04-22-2003, 03:18 AM   #3
Cole Trickle's Avatar
I'm not familiar with these cars, but usually it'll change kick up (front) and anti squat (rear). Kick up give less steering entering corners, but give better handling through bumps. It also give a little more on power steering. I think anti-squat affects the way weight are transferred front/rear during acceleration / decceleration.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-22-2003, 04:46 AM   #4
rccarracer's Avatar
Cole Trickle is right, these spacers control you squat and dive....
rccarracer is offline   Reply With Quote
Old 04-22-2003, 10:15 PM   #5
dsrbltoys's Avatar
You can also use the same spacers front and rear to "raise" the roll center. making the car move more in the the corners for more weight transfer.
dsrbltoys is offline   Reply With Quote
B4 axle spacer question. TKCastle Electric Off-Road 14 06-21-2007 07:31 AM
B4 axle spacer question. TKCastle Nitro Off-Road 2 06-19-2007 09:10 PM
WTB: RD Racing Piston spacer domindart R/C Items: Wanted to Buy 0 05-24-2007 03:48 PM
Motor Question - Spacer Worn - ??? rctoyguy Electric On-Road 2 07-29-2004 11:40 PM
Hot Bodies Front Suspension Arm Block for HPI Pro 3 Aku-Man R/C Items: For Sale/Trade 0 12-07-2003 05:33 PM
SEO by vBSEO 3.5.0
