plugs or melt on the motor?
hey everyone,
is it better for the motor to be welded or whatever on rather than plugs?
To solder or not
A GOOD solder joint is better than plugs, a BAD solder joint is worthless.
For Stock racing, a 'Deans' or similar plug on the Motor and batteries is acceptable. For a Modified Motor, I would ONLY solder because of the much higher amp draws involved.
I would NOT use any of the plugs that come with some Motors, for racing of any type.
oh okay...thanks...i soldered already. makes the car look neater
I race in stock and I prefer good quality plugs, since it's much easier to maintain the motor and switch between different motors.
i don't hav many motors....so i decided to solder...and my wires were getting in the way...now it looks really neat. i'll get a pic soon maybe.
Rule of Thumb:
NEVER ever use original Tamiya plugs either on the motor to ESC or the Tamiya battery connectors with MODIFIED motors.
I find soldering more convenient when you have AC available. I used plugs last season when I raced outside. I had AC from a power inverter that ran from my truck and it didn't have enough AC to run both my power supply for charging and the iron. This year I am going to buy a bigger inverter and I will be soldering.
As long as you use a quality plug like the Deans or Trinity (Corally), you won't notice any performance decrease. Absolutely stay away from the Tamiya and bullet style connectors. These just have too much resistance and will cause problems. In my early days of racing, I melted a Tamiya plug together so badly that the only fix was to cut the wires.
Jeff Gilligan
Jeff Gilligan
Gotpez : Hi
You might want to get one of those butane-powered soldering irons. No kidding, I have one of these and they are invaluable for soldering work where AC is unavailiable.
The model I have is the Iroda Solderpro 50, its equavalent to 50 watts I guess.
Cheers
Cheers
I use a Master Appliances UT-50 butane soldering iron, it's small and when using the wide tip is perfect for cells, wiring etc.
Expensive but worth every cent.
butane questions:
does it work the same way as a/c powered irons? do you need special solder? how long does the cartridge last? thanks for any info
i was looking at one from radio shack and it seems a good tool for outdoor racing with no a/c power.
Originally posted by marvi
butane questions:
butane questions:
A full charge for me lasts abt 20 minutes, enuff for most on track emergency work, hard wiring etc. IF needed, I just carry a small can of butane with me to recharge the iron in the pit... much lighter than an extention cord hehehehe.
Cheers
on mine i like to hardwire (solder) my motors and batteries to the esc. that way if you get hacked you know the connector wount come off
thanks
I race stock and have always solder my motor in the car along w/ my speed control to the batteries and my brushes to the motor. I have always been a firm believer that soldering gives the best connection.
