Core RC 5000mah Lipos...
#586
It was not hooked up to anything, I charged it monday, disconnected it and let it sit, I leave it taped into the car, but it was not connected to the speedo.
I have all the settings correct on the ice charger. I haven't changed them since I purchased it.
I have a race next weekend, So I got the car out to rebuild it and noticed the pack as you see it.
#587
ok well here is a basic one orion says to use now we just need Adam to help us adapt it to the udc 20 please Adam
http://www.team-orion.ch/orion/faq/harness.gif
sorry
sorry
#588
I need some help, this is what my core pack looks like. I have only ran it two weekends, and I only run it once a month, I put it on the charger about a week ago just to put some juice in it. I looked at it today and this is what it looks like . I am worried about the thing blowing up. Also worried that $120 is down the drain. I charged it like normal, I have an Ice charge set for 5 amps. Any help would be appreciated. I also need to get my bottom weight off, any suggestions?
#589
i didn't really pay that close attention, but someone at the track and a adapter they made to balance charge, if i remember correctly they took and servo plug with three wires one had a neg bullet plug, one had a positive bullet plug, the other had the small bullet plug for balancing. it was all plugged into the 2s balancing plug on the charger, i would imagine that if you took a voltmeter to the charger you could figure out which is positive and negative. the center should be the balance wire.
I use an AstroFlight Blinky balancer to balance my Core-RC 5000 pack. It works great and no need to modify anything. Just plug it in and go. Hope this helps.
#590
Has anyone left their Core setting for a month or more and then checked the balance?
I haven't used mine in roughly 6 weeks and didn't check the balance before charging it back up. After it finished charging and was not connnected to anything it swelled up. Needless to say it has been disposed of properly.
At this point I am assuming it went way out of balance while stored at half charge and then overcharged a cell when it was used the first time. My only concern with this theory is that the guys at Schumacher have been saying to not worry about balancing them.
No hard feelings, it was a great battery and didn't owe me anything, just surprised that it swelled after less than 75 cycles.
#591
Has anyone compared the Core 5000 with the new Orion 3800 30C packs?
Skiddins
Skiddins
#592
Super Moderator
#593
#596
From my experience, the performance variances from (SMC, Orion, Core and Reedy) packs are less apparent when running Mod. But when running 17.5 and 13.5 classes that demand higher voltage and lower IR cells, the differences become more apparent. In classes where you're limited in horsepower the battery output becomes more important.
#597
Trader Rating: 32 (100%+)
I have both packs I have about 60 to 70 cycles on my Core 5000 and I just got an Orion 3800 30c pack. They were both the same speed on the first couple of charges on the 3800 then it got faster and faster as the day went on. At the end of the day the 3800 pack was .3 faster fastest lap with a 13.5 motor. So draw your own conclusions maybe a new Core 5000 would be just as fast I don’t know I don’t have a new Core 5000 to compare it to. But in the end I went my fastest with the 3800 that had 4 cycles on it ever and they were that day.
#598
I certainly didn't manage 0.3s difference between the packs, even if I ignore the tyres and setup changes etc the biggest difference I saw was 0.06s!
Maybe after the Orion has 'bedded in' it might get better, but baring in mind I have thrashed the Core's quite a few times over the last 7-9 months there isn't much of a difference at all.
Skiddins
#599
Does anyone know where to buy JST-EH connectors?
