Core RC 5000mah Lipos...
#528
R/C Tech Elite Member
the two outs on the LHS of the case, and this is a guess, but the one that looks like a servo plug, would be for a temp sensor, (i've seen this type of sensor plug on other chargers) the other plug is obviously for a banana plug but i don't know if its input or output, i'm at the track now so i don't have my voltmeter to test to see if there is power there. possible for it to be either, but i'm thinking it is out put and maybe to plug another charger into or some other option.
can't help you with the error message, maybe you don't have the right battery selected, 2s, 3s etc.
#530
Hi Heavy,
Shoot that connector back to us at Schumacher and we'll replace it for you
dodgeguy:
They ordered one last week, so I'd be quick if you want to get a look/buy it there
dodgeguy:
#532
#534
OK first day out on the track with the 5000. Just a practice day, and the battery is AWESOME!!!! I charged it at 5amps on my advantage that is going to be replaced this week by the much smaller Core charger. I will have to say from run to run the battery worked great. I am going to be practicing tomorrow also trying to get runs thru the pack for the nats. I am so pleased with this battery. I will be buying another 5000 to have as a back up. I think these are the last batteried I buy this year.
#536
UDC10: smaller size, 4A max charge rate, and no balancing capabilities. Otherwise the same as the UDC20: Backlit, full selection of charge connectors, and etc.
#537
edit
#540
Long story short: I let someone run my car with Core 5000 Lipo but they forgot to stop running when the battery ran down. Doh!! As soon as I found out, i threw the battery on the charger and charged it to around 50-70%.
Question: How can I tell if the pack has been damaged by overdischarge?
