Old 05-30-2007, 08:36 PM   #1
Default Associated TC4 help please - differential/drive train problem
Hey guys,
I have an RTR TC4 that I recently had a pretty decent wreck with into a curb. It knocked something within the transmission loose, because after the wreck, the car has absolutely no grip in the back two wheels. In other words, the wheels spin, but as soon as I turn the wheel, the car immediately spins out. I took the body off and spun the gear that attaches to the pinion gear which is attached to the motor itself, and unlike before, the rear wheels do not spin. Basically, I believe something is loose within the drive train and am not sure how to go about figuring out what it is and how to fix it. Do any of you have any experience with this sort of problem?
vthenry07 is offline   Reply With Quote
Old 05-30-2007, 10:45 PM   #2
ford_racing's Avatar
Send a message via MSN to ford_racing
it sounds as though your rear diff has come loose
taking the rear diff out of the car. This is done by removing the 6 screws on the case. Then check and see if the bolt which goes through the middle is either loose or broken. If it is loose tighten it up then undo it by about 1/4 turn. I fit is broken replace part.
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 05-31-2007, 09:58 PM   #3
thanks for the advice, it ended up being a slightly different problem than I figured, but I fixed it regardless.
Cyclone 18 Tooth Drive Train Crashmaster R/C Items: For Sale/Trade 7 03-16-2008 04:17 PM
PRO4 DRIVE TRAIN HELP serpentrush Electric On-Road 9 01-24-2006 09:50 AM
TC3 Drive Train runnin rc10 Electric On-Road 15 11-01-2004 01:09 PM
drive train weight, gt7 settings mtc3od Electric On-Road 10 08-26-2004 09:13 PM
V1RR drive train Q in search of A Tom G Nitro On-Road 14 03-08-2004 02:28 PM
SEO by vBSEO 3.5.0
