Old 05-30-2007, 06:56 AM   #31
bxpitbull's Avatar
How can less voltage give you more runtime? Someone on here said think of electricity being water in buckets....bad analogy. If an item is designed to run on a certain amount of voltage, it's going to pull power based on how it was designed....regardless as to how many volts you feed it. And according to the bucket man, more run time is achieved well, with todays cells, running for 5 minutes is as easy as 3.14. I thought going to five cells was to control heating issues, not ensure maximum run time. I said it before and I'll say it again, run li-po, gear your car CORRECTLY and chances are great heating issues will be minimized. No one is addressing gear ratios. I have heard of guys running some really low ratios using 7x2 and 6 singles...then wonder why they have malfunctions.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 05-30-2007, 07:27 AM   #32
TRF415boy's Avatar
5-cell was always a way to stop BLOWING motors and speedos in both brushed and brushless. With regard to this, it has been successful.
We do pull more amps than before and it's very easy to see. Before with 6-cells and a 7T you would last easily the 5 minutes, now you can't, you need a brushless to last 5 minutes. Given that the capacity of the cells is still the same, we are still using IB 4200s as last year, then the amp draw must have gone up.
TRF415boy is offline   Reply With Quote
Old 05-30-2007, 08:10 AM   #33
gacjr0's Avatar
Trader Rating: 15 (100%+)
The amps go up in the 5 cell applications because to get the speed you want you have to motor up and gear up. A 6 cell or lipo driver can use a slower wind and easier gear ratio and still be overpowered. Bxpitbull has it right.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
F/S - 4 cells 6 cells IB4200 Batteries for TC or Trans Am Solara R/C Items: For Sale/Trade 5 08-11-2008 08:38 AM
2 packs Power push 3600 intel. cells,4 cells whynot R/C Items: For Sale/Trade 0 05-31-2005 08:01 PM
XRAY T1FK - RC12L3 - Serpent 710 - Surge Batteries (4-cells & 6-cells) and more XrayRacer R/C Items: For Sale/Trade 24 03-31-2005 02:19 PM
1.18+ cells -vs- orion's 1.19= cells dawgmeat Electric On-Road 142 03-31-2005 10:01 AM
SEO by vBSEO 3.5.0
