I would do away with the trust bearing and simply at this time replace it with just thrust balls, though a few more than standard. I currently run the balls from the Schumacher Pro Thrust Race but will have the Serpent one's from the Centax clutch soon (they are carbide and the right size to fit roughly 8 around the diff screw. this way you get a much more even load, plus no friction from the thrust cage.
Thanks RCMarket!
jo90, would that really work if you would just throw in some thrust balls between the thrust rings? wouldn't they all mix up and 'follow a different path', if you know what I mean? In other words, just throw away the thrust cage and that would do the job? ofcourse replace the balls with carbide or ceramic....but still.
Thats all most thrust races are
I am currently using Edit cyclone thrust race balls whilst still using the serpent plates.
Govert. Yep it works fine. The thing is though there is no track as such, the actually balls will not run out the washers as they are held in place by the diff outdrive itself. they all fit snug in between the washers, but with enough slack to allow movement which is what you want. Both I and Natahn have been running like this for a few meets and it has worked perfectly, the diff has given excellent longevity and stay smoothes for ages. I will hopefuly be getting feed back though from my team manager on the thrust race though soon.
Just make sure to you put plenty of black grease on the balls and plates - and away you go !
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
Thanks for the tip! You're right about the fact the balls will stay in the outdrive. One last question I forgot; should I still roughen up the thrust rings by sanding them? Let's see what happens after the change.
Dont do anything with the plates, and to be honest the best thrust race we have found to be at the min is the Tamyia one piece one. Pack it fully with a good grease and you cant go wrong. We have tested a lot of differant combos latley and found this to be the most consistant.
use old thrust rings is good ,
but i'm many user like use 1pc thrust bearing ,
use Carbide or ceramic ball same have good choice !
& Rear diff. cup , can choice Yokomo BD Diff. cup , had many user used !
I am in desperate need of a ONE-WAY.. anyone got an extra to sell? or know of where to get one? The US distributor hasn't even received them yet from Serpent.
Please help!
you can try the HB One way with little mod.. or Ta05 one way or 415Msx one way...
