Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-27-2007, 04:19 PM   #781
401100 front diff
for some reason my preview wont open since i installed adobe
Corally, SMC, Tekin, Checkpoint, Futaba, Jaco, MuchMore USA, Protoform, Parma, PRS, BMI, TQ Wire, Power, Paint, Team Tamale, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-27-2007, 04:21 PM   #782
StadiumChris's Avatar
Trader Rating: 22 (100%+)
it will not open a window.. it will only show the icon in the dock as active. Drag your file over the top of the preview icon in the dock and it should open.
StadiumChris is offline   Reply With Quote
Old 10-28-2007, 02:23 AM   #783
markp27's Avatar
Send a message via ICQ to markp27
Hi Jeff,
To save a protected PDF on the Mac, go to print and then click on the PDF button at the bottom left of the print window.
Now save the document as Postscript and not as PDF.
Now open the Postscript document which you have saved and go back to print and click once more on the PDF button in the print window. This time save the document as a PDF.
That's it
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 10-28-2007, 12:47 PM   #784
Just wanted to share.. here is a pic of my two Serpents... the second one is waiting for the foam conversion kit. Already ordered on Friday, the day it was announced. 1st car is rubber, TC Spec w/ 10.5 motor, wired for room to fit Much More motor freezer.
Also.. anyone know whos turnbuckle wrench fits the Serpents?? I like the steel buckles, gives me a bit more traction.
Everyone should have the shock tool also, makes working with the shocks, MUCH easier.
Old 10-28-2007, 03:17 PM   #785
Gergely's Avatar
For Mr.820post information,
I would give a try to the original Serpent #1461.
http://www.serpent.com/product/1461
http://www.serpent.com/product/ Useful link
Not bad from a guy who has only 10 post, right?
Very nice cars anyway, lucky to have two ones already
What type of servo do you use?
Gergely is offline   Reply With Quote
Old 10-28-2007, 03:29 PM   #786
Thumbs up
The perfect turnbuckle wrench.. had to order, no LHS carries them:
http://edsracingproducts.com/TURNBUC...B000XAH08W.htm
I'm a Futaba man, so S9551 servo it is.
http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML
Just fitted my Peak Racing 3200 in the chassis without much modification. Also using the Nexus Racing Lipo lower weights to bring the CG down.. after weighing it in, our track weighs our cars, 53 oz. Perfect! With EP or IB4200s, nearly 60 ozs.. ouch!
Old 10-28-2007, 03:44 PM   #787
Gergely's Avatar
I'm running with a Sanwa WRX servo now. I want to buy a 9551 or 2413 (no light low-profile Sanwa ) to get rid of the unbalance (5-cell, BL) and get closer to the weightlimit, but haven't decided yet... What do you think? Pros and cons?
Old 10-28-2007, 04:03 PM   #788
yyhayyim's Avatar
Trader Rating: 24 (100%+)
Well...I gotta admit it...is the S400 a great car or what? I have tested ran it now for almost 14 packs...the car was great from the start when I first ran it about a month ago at our Coral Springs, FL track w/ my 3.5BL and Lipo combo...from there I have taken it to the nice MDI track in Royal Palm beach a couple of times, and the car is just the best I've ever had...I cant explain why...the car just works- it really performs...its fairly light,yet strong in the key drivetrain parts for better wear and duarbility. Its very easy to build and set up...
Today at our Coral Springs track, I tested w/ my LRP 3.5 motor and the car was so good...perfect, I'd say.
After 1 pack, I replaced the 3.5 motor for a 10.5 BL motor...the car was dialed, too! What car gives you such a wide sweetspot and versatility...this is really a very good car- it's amazing.
I ran it for a few more packs untill the tires ripped and were useless...what a day...what a car
yyhayyim is offline   Reply With Quote
Old 10-28-2007, 04:07 PM   #789
teammidget lilB's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to teammidget lilB
Hey guys I just got back from the state arce wich I choked at!!!! Going in to it I was leading by one point and the guy in second finished first and I finished third. My car was really really good I will try to get my set up on here in the next day or two. What I did do was I went to 2 degree caster blocks and 1 degree of toe with .5mm of kick up and 1mm of antisquat!! Hope fully in two weeks I will do better at regionals!!!
Bryan
Bryan "Lil B" Ford
T.O.P. Racing USA - SMC Batteries - High Velocity Racing .com - RCiD - Upgrade - Publix
teammidget lilB is offline   Reply With Quote
Old 10-28-2007, 06:07 PM   #790
KAHUNA's Avatar
Cool
Originally Posted by Jeff Cuffs View Post
401100 front diff
any web site , I cant find one that has it .....
thx....
- * * Team Scream Racing * * Diggity Designs * * DARKSIDE DESIGNZ OF MD. * * * * TheRCShack * * www.teamscreamracing.com * * www.diggitydesigns.com * * www.thercshack.com * * www.darksidedesignz.com * * www.teamfullthrottle.net * * *Tom Brown* - Diggity Designs XLR8-V2 * Cowabunga Dude ! * *
KAHUNA is offline   Reply With Quote
Old 10-28-2007, 08:20 PM   #791
im not sure who has them in stock
Old 10-29-2007, 04:42 AM   #792
ygpm
Bryan "Lil B" Ford
Old 10-29-2007, 09:54 AM   #793
RevMaxx's Avatar
Send a message via MSN to RevMaxx
i understand the kit runs pretty well as it currently is, but just want to know if does anyone know if an '08 version of the S400 is being brewed?
much like what happened to S720 which later had the '07 version
RevMaxx is offline   Reply With Quote
Old 10-29-2007, 11:59 AM   #794
yyhayyim's Avatar
Anything is possible...but Serpent has taken the time to really put out a great working car from the start. It doesnt just "run pretty well"...its exellent. What they'll probably do is revise or update certain parts, if needed, much like the development of the HB Cyclone. Its exactly the same car, but in 06 the HARA edition came out with better quality parts, and then the MooreSpeed edition, with better parts, etc...In 2008, look for Serpent to work on some refinement to the servo saver area, which needs a little sanding down/dremmeling for it to smoothly clear the bulkheads(takes a minute). It'll be little changes/improvements like that...the kit is top notch and it doesnt need new versions like Xray T2- which every year is like a new car...
Old 10-29-2007, 12:47 PM   #795
Gergely's Avatar
Mine fits perfect without any dremeling
Originally Posted by yyhayyim View Post
...In 2008, look for Serpent to work on some refinement to the servo saver area, which needs a little sanding down/dremmeling for it to smoothly clear the bulkheads(takes a minute)...
Forum Jump
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 11:04 AM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 05:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 04:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 05:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 05:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
