I would say Serpent just dropped us on our A$$ with this car. You cannot get plastic for it once the supply runs out. They are doing the same with the 720 line it seems. Anyone know if the HB plastic will work on the car? If not I am done with Serpent and all 3 of my cars are going in the trash.
Pissed off customer.
Mr Granone:
Unfortunenly that isn't serpent decition to discontinue the car. It was the manufacturer that claimed something imposible. For the 720, teh car will be supported at least for about 1.5 years,after the new car or farther if parts are sold. So far, the are parts at Serpent America. In the following weeks more parts wil arrive.
tbh, when i'm done with my spare parts for my s400, i'm done with serpent...
it's a good car... but "manufaturer claim something imposible"..? come on...
i might u put it into my shelves... actually i have prep my car for up coming races... i keep parts worth more than usd500... n i'm running 2 s400... 1 for practise n i for race... so u might guess how much have i spend... i can easily afford another kit too... but i've been loving serpent since the GP car...
bye bye 733... just cancelled my order...
There are more in racing than winning.
Serpent learned a lot from this. The no only loss the S400, the F180 was also make by this manufacturer. Now parts are done with differents manufactures and kits come together in house. This helps in case one manufacturer give problems they simple just look for some one that can make that part and supply continue.
I am pretty sure that you will not be dissapointed with the 733.
For those looking for spare parts that can fit. Somebody told once that there is Tamiya car that fit parts.
since 3 Racing can produces whole HB cyclone parts, tamiya, Losi, etc, square produce tons of yokomo n tamiya parts, n many many more... y can't serpent get someone else to make them parts..? can u give me the CAD drawing of all the parts..? i only understand that plastic parts r a bit harder to make... plastic mold injection..? well, it can still be done...
nah, just relieving some griefs... it's not ur fault, it's "serpent" problems...
alternative parts for serpent s400
rear ball diff outdrives (cups) Yokomo bd rear diff outdrives with
- Yokomo outdrives with rings
- Yokomo diff screws, spring and nut set
- Yokomo diff plate
- Yokomo trust bearing set
center 16T pulley HB cyclone 16T or Tamiya 16T center pulley
cvd Tamiya 46mm or 48mm cvd with
- Tamiya CVD insert
belts Tamiya TRF415
axles Tamiya TRF415
FRONT SPOOL OR ONE WAY..?
has anyone tried TRF415 unit with their 3 holes 35T pulley..?
anyone have this 1 piece upper deck..? it is design by V-dezign... this is their last upper deck design for S400... mind to scan (or CAD file) the top deck n send to me..? i think i can ask someone to make me some...
I don't know if I am the only one breaking/bending them, but my largest concern is not being able to buy rear bulkheads. Can't drive the car without those, and it's less likely to be able to use the parts off another kit.
Thats what I was thinking. Thanks for posting the list of compatible parts.
- Yokomo diff plate
- Tamiya CVD insert
belts Tamiya TRF415
axles Tamiya TRF415
hi everybody
i can add some more part to the list, and also answer the question on the 1-peice upper deck.
you can use xray c-hub and steering block, fits perfekt. (remember to buy the xray aksels)
TAMIYA TB EVO 4 rear uprights (need 5X9X3 bearings) fits perfekt. just remember that they are 2mm lower then the serpent std.
xray belts, they make a 501mm belt and a 180mm belt.
the 1-piece topdeck works very well, it makes the car more stable and it dosnīt tweek that easy.
Steven Olsen
Sponsored and Teamdriver for:
Superhobby.dk, AE77-Racing.dk, TAMIYA, LRP
CAR: TAMIYA 416WE
Powered by;TAMIYA, LRP Batteries, LRP SPX and LRP 17.5 motors
StevenOlsen:
mind to scan ur upper deck n send it to me..? i can ask some one to cut me 1 if i can get the actual size picture of it... i'm thinking to make it using 2.0mm carbon plate... should give more flex thus might give more grip in low traction track... V-dezign no longer sell them... or anyone that has CNC machine that can produce the upper deck for us here..? i guess we can make a group order... i'm up for 2 units at least...
M-Technic:
rc-mushroom dot com got them in stock... rear upper bulkhead... i broke mine too before... or u can actually use the front unit for rear too... but u need to add 2.5mm shims to uprights... anyway u can always tune to what u like... front unit r much stronger than ori rear unit...
TFRacing makes some upper deck n lower chasis for S400...
Jaad racing has shock tower...
StevenOlsen:
M-Technic:
here is the picture. is it okay?
I have also found more parts that will fit the s400,
tamiya TB EVO 4 suspention arms
Tamiya c-hubs and steering blocks
Steven Olsen
CAR: TAMIYA 416WE
thank you very very very much for the top deck picture... it's version 2 of the 1 piece top deck... version 3 is slightly different but this is good enough too...
tamiya 416 arms can fit too... but have to use tamiya c-hubs, steering blocks and uprights...
We just got word from the factory, that a solution has being found and that supply for parts is not going to be a problem anymore. Order and shipment is already being arranged in order to have parts available in our warehouse in USA.
We appreciate your comments and support. We felt was fair to let you guys know what was going on even if we know we may have create some inconvenience.
anyone selling their gear diffs..?
Where did u quote them from? I cant find that post anywhere
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
belts for 36T front/rear pulleys with 18T center pulley..? i'm trying to get tamiya trf416 18T center pulleys with TA05 36T front/rear pulleys... thanks...
it was an old post by serpent... well, they gave us hope but it's now nothing...
Originally Posted by boba.slave
Take a look at the date!!
It's dated at the end of 2008.
A week ago I've sent a mail to Serpent concerning the S400-problem. Till now I haven't received an answer from them...
Very professional, I would say!
I've had it with Serpent... my next car will be another Xray again!
actually xray ain't expensive at all... serpent parts ain't cheap too... i have most parts for me to run it for a year or more... coz i keep a lot pf spares... but i'm not sure which parts will run out of stock before i got to frame up my car... i love it, but i can only keep it (not actually running them as much as i wanted to)...
so for whoever still wish to run this car, i guess we got to share solutions here...
anyone looking for LiPo upper deck made by V-Dezign..? they just reply me, i can make a group purchase if u guys interested... after i got it then i send them out to u guys... anyone..? let me know asap...
