Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-16-2008, 11:40 AM   #2221
Randy Caster's Avatar
Originally Posted by kschu View Post
guys, i jus notice tat billy easton car during warm up race got abit different.. d servo mount like tamiya trf415.
He had to mount the servo like that because of other changes he made, the servo itself wasn't so much for a performance advantage, it was just so he could fit the electronics on that side of the car.
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
Old 06-16-2008, 11:41 AM   #2222
Originally Posted by yyhayyim View Post
Hi Randy...would you care to comment on the feeling of the S400 gear diff vs ball diff you've run in the past?
When you get a chance I'd be cool to get your perspective on the feel of the car in and out of corners with the gear diff as opposec to a rear ball diff.
I haven't yet run the Serpent ball diff, I had the gear diff from the start, but I will be using a ball diff in my 10.5 car this week at the nats. Basically a gear diff just doesn't slip at all, so if you punch it, all of the power is going to the tires rather than having some of it slip away like a ball diff would.
Old 06-16-2008, 04:32 PM   #2223
kschu's Avatar
Trader Rating: 14 (100%+)
Send a message via MSN to kschu
Originally Posted by Randy Caster View Post
I'm not sure why you're wearing out pulleys, I looked at my origional kit's pulleys and they show no wear at all... Go back to the stock ones with the new belts and you should be fine.
randy, is it your belt tension put to tight position( which hole u use from the bearing holder) ?
Team Yokomo * Team Roche
http://www.kkeprc.com (RC News)
kschu is offline   Reply With Quote
Old 06-16-2008, 04:34 PM   #2224
kschu's Avatar
since you using tamiya shock now, wat u think between d s400 rcc shock and the tamiya shock ? both work d same or not ?
Old 06-16-2008, 06:33 PM   #2225
When I run a new belt I set the tension fairly tight, but not bound up, once the belts break in they free up perfectly.
I run the Tamiya shocks for more dampening adjustability with the option to put foam or o-rings above the bladder for quicker rebound. I'm sure if they were set up the same as a Serpent shock's rebound they would feel near identical.
Old 06-16-2008, 06:51 PM   #2226
kschu's Avatar
i having difficulty to make d s400 shock to bleed and bound perfectly....thus making my all 4 shock have different rebound rate....in d mean time, s400 shock service kits are very expensive...
i think i might jus get a trf shock to clear out d problem....wat parts tat will alway wear out if i use trf shock ?? o-ring ?bladder?foam? please advise......
Old 06-16-2008, 06:57 PM   #2227
yyhayyim's Avatar
Trader Rating: 24 (100%+)
i having difficulty to make d s400 shock to bleed and bound perfectly....thus making my all 4 shock have different rebound rate....i think i might jus get a trf shock to clear out d problem....
Kshu..the RCC shocks are super easy...just fill them up, and wait for the bubbles to clear. Extend the shock shaft all the way out and then close the shock up and screw it in but only about half way. Then just slowly push the shaft down about 3/4 way and fully close the shock...you should have about 50% rebound. try it. it will take like a minute.
yyhayyim is offline   Reply With Quote
Old 06-16-2008, 07:26 PM   #2228
kschu's Avatar
but it's cant completely compress in d shaft rite?
Old 06-16-2008, 07:29 PM   #2229
yyhayyim's Avatar
right...once you screw in the cap with the shaft, screw it in about half way, and then the shaft you push in slowly, and some oil will start coming out. screw it full and then check rebound.
Old 06-16-2008, 09:27 PM   #2230
Also be sure to soak the foam in the shock with oil before assembling everything, this will help to keep air bubbles out of the shock.
Old 06-16-2008, 09:59 PM   #2231
RC MARKET's Avatar
the shock inside foam need keep to repair to new one !
RC MARKET is online now   Reply With Quote
Old 06-16-2008, 10:02 PM   #2232
RC MARKET's Avatar
or direct change Tamiya new black color limited shock !
Old 06-16-2008, 11:05 PM   #2233
Well I'm off for the nats in the morning, be back next monday night, talk to you guys then!
Old 06-16-2008, 11:14 PM   #2234
UK.hardcore's Avatar
Good luck and have fun!
By any chance, do any of you run the gear-diff with 1000CST oil?
They leak like hell.
Our friend who races Nitro 200mm said we should use thick sticky grease on the o-ring that seals the diff-halves?
Any other opinions?
I notice mine doesnt leak with heavy oils, like 100.000 CSt, but with 1000CSt it leaks.
RC8T FT in pieces.
RC10T4 FT hibernating.
HB D8T powered by Hyperion Gen3 LIPO.
Eat my dust!
UK.hardcore is offline   Reply With Quote
Old 06-16-2008, 11:51 PM   #2235
RC MARKET's Avatar
Any other opinions?
HK some peoples use Kyosho 5000 oil,
but i'm feel maybe can use around 1000 oil or lower .
Forum Jump
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 11:04 AM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 05:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 04:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 05:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 05:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
