Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-03-2008, 10:13 AM   #1561
nikoskar's Avatar
Originally Posted by TeamButter View Post
There is a new thrust bearing assembly. The original one did not hold up so well and the diffs did not last. Serpent identified this issue and released an improved thrust bearing that will solve the issue. Purchase the new thrust bearing and install it and the problem is solved.
Clear enough?
ok thank you so much.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 04-03-2008, 10:20 AM   #1562
Administrator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Thanks Randy.
Originally Posted by Randy Caster View Post
I sit the chassis on 10mm droop blocks, and measure from the setup board to the top of the axle.
Jesse@pc9840.com <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 04-03-2008, 10:24 AM   #1563
TeamButter's Avatar
Send a message via AIM to TeamButter
No problem!!!
Serpent-Xceed-JACO-CEFX-EA Motorsports-Novak-KO Propo-TeamButter-P3 Graphics-MDI Racing
TeamButter is offline   Reply With Quote
Old 04-03-2008, 12:59 PM   #1564
Randy Caster's Avatar
Originally Posted by Ryo Saeba View Post
Randy, what's the different about the original shocks and TRF shocks when you drive the car with the same oil and pistons?
thanks..
The TRF shocks just have the bladders which makes it a little easier to adjust rebound, once I find the feel that I'm really happy with I'll use the stock shocks and build them to get the same feel.
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
Old 04-03-2008, 01:00 PM   #1565
Originally Posted by pc9840 View Post
Thanks Randy.
No prob, hope you like the setup! If you're ever at BCR feel free to drop by and ask any questions.
Old 04-05-2008, 02:36 PM   #1566
stegger's Avatar
I know you can get a foam chassis but is there or any plans to release a complete foam kit. I don't want to buy a kit and a foam chassisThanks in advance...
stegger is offline   Reply With Quote
Old 04-06-2008, 05:36 PM   #1567
kschu's Avatar
Trader Rating: 14 (100%+)
Send a message via MSN to kschu
hi randy, i try ur method by cutting d upper deck, i do notice it's make d car more steering/responsive for front!....now my car is oversteer when using d same setting like last time......hahaha....
now i need to find new setting for it....
Team Yokomo * Team Roche
http://www.kkeprc.com (RC News)
kschu is offline   Reply With Quote
Old 04-06-2008, 08:49 PM   #1568
I love oversteer
Old 04-07-2008, 01:26 AM   #1569
kschu's Avatar
i read some infos around, it's said oversteer can b cured by putting Tyre Treatment ONLY at d rear Tyres....this will make d car easier to drive....
i haven't test it yet bt will do it on this coming saturday....
I just finished my 1st race of HPI Stock 23t challenge yesterday with my team mate Jayjay....fighting with team Hotbodies...
2 serpent vs 9 Hotbodies....
i came out in 1st position and jayjay in 3rd place..
Old 04-07-2008, 07:08 AM   #1570
Just so the traction feels consistant, I would keep saucing the front tires. You could try saucing less of the tire, maybe the inside 75-80%. A thicker swaybar is also an easy fix to an aggressive car, front kickup, or less sweep in the front arms would be things to try.
Old 04-08-2008, 02:14 AM   #1571
kschu's Avatar
is it front kick up mean put shims below d front toe block ???
how to do less sweep in d the front arm ?
thanks
Old 04-08-2008, 07:34 AM   #1572
thanks
Kick up is more shims under the front block, this will make the car less aggressive on corner entry but give a bit more steering coming out of the corner.
Less front sweep would mean rather than running a 3* front block and 1* rear block, you could run 2* on both to make the pins straight and keep the width the same. Or you can experiment with different combinations to find the width and feel that you like.
I run a 2* in front and -.5* in the rear, which is very narrow with a lot of sweep, and .5mm of anti-dive (shim under the rear block) which makes my car very aggressive going into the corners which will help give the little extra edge if you are trying to pass someone close to the same speed as you.
Old 04-08-2008, 06:18 PM   #1573
corallyman's Avatar
Trader Rating: 58 (100%+)
Randy,
I got a few questions for you. You just posted some adjustments that you use for the front of the car, do you try much in the rear of the car? Do you play around with anti-squat or pro-squat. Also what body do you run, do you have a favorite 95% of the time or do you adjust the car by body also?
Thanks,
Steve
Team Serpent- Serpent America- Xceed Products- MEGA- Maxy Fuel
Team Epic / Team Trinity
Hangar 30- EGTC Silver Cup Series
corallyman is offline   Reply With Quote
Old 04-08-2008, 06:54 PM   #1574
I very rarely run pro-squat anymore, I used to a lot to help the rear of the car stay planted on the corner entry. On my current setup I do run anti-squat, which I feel helps the car rotate a bit better in the corners, but may feel loose on some tracks.
My favorite body is the Mazda 6, seems pretty balanced and has good steering. If the rear end is too planted I will run the Mazdaspeed 6 which is a little twitchier off center, and has a little less rear end traction generally.
Old 04-08-2008, 07:04 PM   #1575
Trader Rating: 19 (100%+)
Wow Randy, you really have become quite the answer-man. I have only one question for you; exactly how long have you been an FD?
patrick is offline   Reply With Quote
Forum Jump
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 11:04 AM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 05:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 04:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 05:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 05:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
