Notes:
-5 cell chassis used, receiver mounted in front of
batteries.
-Upper deck was cut to allow more flex. (see pictures)
-Used 2 gears in rear diff.
-TRF shocks with stock Tamiya bladders with nothing
above.
-Tamiya pistons used.
-AE lower spring retainers, and shock ends with 2mm
cut.
-.5mm anti-squat.
-Front pivots raised .5mm + .5mm anti-dive.
-Steering limited 1mm with spacer glued to knuckle.
Edgar Daniel, de Pompano---este loco de donde lo sacaron? Ese set up esta en chino...mira pa eso- sacando droop, anti dive, hay mi madre...me va dar un patatu
Notes:
batteries.
above.
cut.
-.5mm anti-squat.
Does anyone else have problem with kits ball rear diff?
I run Brushless 3.5T and 4600 Batteries and everytime something is broke down. The plate,the balls etc. I think i change to the new one with lub.
There has been a revision to the thrust bearing assembly that will resolve the issue with the diff's longevity. It is available to the public now.
Butter
Serpent-Xceed-JACO-CEFX-EA Motorsports-Novak-KO Propo-TeamButter-P3 Graphics-MDI Racing
Butter
Thank you for your answer.But can you be please more specific?
There is a new thrust bearing assembly. The original one did not hold up so well and the diffs did not last. Serpent identified this issue and released an improved thrust bearing that will solve the issue. Purchase the new thrust bearing and install it and the problem is solved.
Clear enough?
