Is there a new Serpent 1/10 190mm body? I notice my brother picture from Germany and he was using this new looking body from serpent. Any have picture of it or info
Thanks guys for all the help!
I am anxiously awaiting those new cvd axles. For now i will order a spare. Also i can see why the aluminium arms would be a nice upgrade, no slipping on that grub screw. Anyone using them?
Any one else diff tighten up on them? Anyone using the new rear oil diff?
Whats the difference with a front one way as compared to the spool? I was told the spool is power on steering increased power off steering decreased.
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
aluminium C-Hub is a good option to upgrade...hehe...
front 1 way gv more steering than spool bt it's depend wat driving style r u prefer...if u play mod, spool is reconmended as it's allow u to use Brake...some ppl still use 1way, but i owes see him overshoot....
if u play stock, mostly ppl will reconmend u use 1 way..some said, 1 way gv u faster lap time than spool...but i feel tat spool n 1 way dont have diff in lap time n for me, spool is more controllable than 1 way...at least u can do last minute braking in corner while 1 way need to off throttle a few Feets before d corner....
Just a heads up for those interested, I've been getting a lot of PM's for the setup sheet that won't load, I e-mailed it to a few people to try and post up here so hopefully we'll see it on here in the next day or so!
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
Great Job Allen and Conner. It would be great if you could post your setups and show others what it takes to be consistent with there S400's .
Conner should scare us all in a few years, but then girls will beginr to pull his interest and real cars and maybe we still have a chance.
www.molzermoweryracing.com
MMR Direct Minnesotas Premier Indoor Race Facility
North American Importer/Distributor Factory Support for FG, Modelcargo, Serpent, Samba, FF Concepts, RayWood Videos
Notes:
-5 cell chassis used, receiver mounted in front of
batteries.
-Upper deck was cut to allow more flex. (see pictures)
-Used 2 gears in rear diff.
-TRF shocks with stock Tamiya bladders with nothing
above.
-Tamiya pistons used.
-AE lower spring retainers, and shock ends with 2mm
cut.
-.5mm anti-squat.
-Front pivots raised .5mm + .5mm anti-dive.
-Steering limited 1mm with spacer glued to knuckle.
Serpent-Xceed-JACO-CEFX-EA Motorsports-Novak-KO Propo-TeamButter-P3 Graphics-MDI Racing
I have create a form like on the xray site for the s400 setup sheet. You can save the pdf on your computer as I still have to finish it so that it will save the form like on the xray site.
Just what he wrote...GEAR diffs... no more balls and diff rings. Chnage the diff lube to suit track conditions and you're done. Serpent is the only manufacturer to offer this for an electric sedan but you can bet others are working on them now...
If I remember Josh Cyrul built a Kyosho (prototype) TC with a gear diff in '05.
