Where to get 48p Metric w/2mm shaft hole?
Does anyone know where or if anyone sells this type of pinion? Need a 11t or 13t.
The 2mm shaft hole is the tricky part.... small electric helis use this shaft size, or try some of the smaller rc cars... Actually HPI has a whole line of them in 2mm shaft size for the RS4 micro...
The pinion needs to fit on a 2mm shaft. (Tekin Rage BL Motor)
To fit match a spur gear from what car? Vendetta? rc18?
Motor is going in a vendetta st.
Sorry looked and couldn't find one even on heli sites. The rage is too small for the vendetta. Look for a 380 or 400 size motor. These will come with 2.3mm shaft diameter and you can use the stock pinions.
BTW are you the same RC10TC on the rcracing site? If so ask racenut.
