Hot Bodies Cyclone12
#121
#122
do somebody got a setup for carpet mod ?
#123
I had a HB C12 and I replaced that on the front of the car and also the rear axle for a IRS rear axle from Team Associated (RC12L4). Then you will have a real performer...
#124
why u want to use irs axial why not the stock?
if u want to use the prisma wheels u can put some shims on it 1/4
i like to use the M4 nuts
i don't like the plastic nuts from irs
#125
shocks
Does anyone have a source to get the shocks for the cyclone 12?
#127
I am curious where you use the M4 nuts then, do you use them to space out the axle so you can use the Prism wheels? If so than I guess you will place 3 nuts on each side between the wheel and the hub. That will never run 100% true and also creates more work on the car when you change tires. If you did mean to put some 1/4" axle shims on the axle itself. That is not enough to compensate the 3mm offset of the Prism wheels and therefore the rear end will be narrower than it should be. I have owned a C12 and tried both of these things to compensate the offset of the Prisms and both of them didn't work...
I also don't like the plastic nuts from IRS and therefore I placed a Slapmaster Thrustbearing on the axle. It has a aluminum nut and makes the diff super!!!
Joost K.
#129
i just use 2 M4 nuts
and i use the corally thrustbearing on the axial it fits perfect
here is some pics
here is some pics
#130
BTW the boddypost from the cyclone 12 is crep
use the one from asso L4 or CRC
#131
your market have T-bar ?
#132
I'm sorry? What do you mean? The C12 is equipped with a T-bar, that is correct or are you looking for spare T-bars? You can also use the AE RC12L4 T-bars...
#133
#134
I always used the AE T-bars, they easier to get & cheaper too!!!
#135
