Old 10-25-2007, 07:53 AM   #121
mog ruith's Avatar
im getting a ifs kit soon
so what hop up do you guys usually get first?
mog ruith is offline   Reply With Quote
Old 10-25-2007, 08:50 AM   #122
Get the ta05R then convert it over to ifs. You'll get all the goodies you need with the 05R and the conversion is simple.
DirtyRacer is offline   Reply With Quote
Old 10-25-2007, 01:52 PM   #123
MonkeyNuts's Avatar
I paid about 19 to convert my TA05 over to IFS, and that was with the hop-up parts
Liam
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 10-25-2007, 10:33 PM   #124
mog ruith's Avatar
i didnt think of that... btw its ont the way now...
so im asking wat to get hop up first usually
Old 10-26-2007, 11:09 AM   #125
TEM
TEM's Avatar
Can someone please give me a straight forward parts list to convert my 05 into an IFS. Part numbers would be appreciated. All I really want to do is to run the 350R body. do I just need to do the front end suspension or rear too?.... thanks!
TEM is offline   Reply With Quote
Old 10-26-2007, 11:17 AM   #126
page 3 of this thread lists the parts, rear suspension is the same
Old 10-26-2007, 10:19 PM   #127
foampervert's Avatar
Send a message via MSN to foampervert
Default TA05 IF/RS...
hiya IFS brothers!
ima just completed my IF/RS car. lotsa epoxying, dremeling and bolting. let's see if it works.
have fun!
-alexander
p.s. for those of you who are contemplating conversion from your regular TA05 to TA05 IFS, it is important to use all the IFS parts for it to work properly as intended. this includes the front steering knuckles, and c-hub. i realised it was different when i printed out my blank setup sheets. also, the smaller c-hub gives the front lighter un-sprung weight. actually, as far as possible, lighten the suspension as much as you can for greatest effect. (by the way, this is for ta05 iIFS, not my conversion )
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 10-27-2007, 12:13 AM   #128
i like that conversion, i thought about doing that. how does that handle? what are you doing about mounting the rear end of the body?
Old 10-27-2007, 08:14 PM   #129
bugnet's Avatar
I was in doubt if go in TT01, TB02, or TA05 (many versions), reading this thread, I'll go with a TA05 IFS for sure now, someone know the difference between #58389 EBBRO BTEC Maziora 350R and the #58394 Eclipse Advan SC430 bodies, to use outdoor on track ?
track is this
http://www.aarcdoabc.com.br/modules....showpage&pid=3
shorter path,
thanks
bugnet is offline   Reply With Quote
Old 10-28-2007, 08:18 PM   #130
Patriiick's Avatar
the ebbro is better, very stable and consistent, it s the body of choice for the tamiya cup races here..
Patriiick is offline   Reply With Quote
Old 10-30-2007, 09:38 PM   #131
Kevin CBR's Avatar
Start with the TRF aluminum shocks and universals front and rear. Makes life and adjustability much easier.
After that, it depends on what you want to accomplish and what your budget will allow. Carbon parts trees will stiffen the car. Aluminum suspension blocks will increase adjustabilty, and there is plenty of blue bling that just looks good.
Kevin CBR is offline   Reply With Quote
Old 10-31-2007, 09:05 AM   #132
bugnet's Avatar
51297 could be used instead of expensive 53899 ?
Old 11-01-2007, 10:14 AM   #133
hi guys. just wondering a couple of things.
i am about to purchase a TA-05R from tower hobbies (found a $30 off code) and do an ifs conversion on it as i have a couple of good books on suspension setup on (real) cars and know a thing or two from the Formula SAE project at uni.
i was wondering if these 3racing alloy c-hubs are similar to the ifs versions or should i not bother as i'll be getting the 05R chassis?
also, are these products necessary for the conversion?
TA-05IFS C-Parts
TA-05IFS D-Parts
TA-05IFS E-Parts
sorry if i've gone over old ground, just wanting a clarification as i'm fairly interested in how this will go, especially since it's my first foray into r/c
tkdwarrior is offline   Reply With Quote
Old 11-01-2007, 11:21 AM   #134
Default TA05-r to TA05 IFS conversion parts...
TA-05IFS C-Parts
TA-05IFS D-Parts
TA-05IFS E-Parts
okies,
here is a list of stuff you need to get if you are converting from ta05 to ta05 IFS; exclude all the red items if you own a ta05R cos you already have those parts in your kit.
- N-part = 51294, can be replaced with reinforced N-part = 53991 (you will need to get 4 850 bearings for the rocker arms unless you get 53993 which comes with bearings)
- F-part = 51293 (trust me, its not the same)
- C-part = 51296 (trust me, its not the same either)
- 3x9.5 step screw, comes in a pair = 9805840
- rocker nut, comes in a pair = 9808126, can be replaced with aluminium rocker nut = 53992
- aluminium rocker arm set (for bling, cos you get real good and stiff rocker arms with 53991) = 53993
- carbon rear shock tower = 53994 (also for bling)
- LW reversible arms (your choice, hard/soft/short/long) and corresponding axles (ta05R owners already have these arms).
- E-part = 51298 (ta05R owners already have this)
- 2 3x0.7 aluminium spacer (from wherever, you can get this in a pack of spacers or singly)
- 2 28mm turnbuckles
- 2 4.6x4.7 flange tube (for the steering knuckles) = 51100
- 2 4.5x3.5 flange tube (for the steering knuckles) = 9808021
- 2 5x8 ball connector
(for the steering knuckles) = 53969
slap them together and you will have a TA05 IFS!
good luck!
-alexander
p.s. dunt bother with the alloy steering hubs as you will spend a minor fortune on replacement bearings... non of the parts you listed are neccesary, only the ones in my list.
Old 11-03-2007, 06:10 AM   #135
Cheers! Just accumulating parts now... will post pics when i get it all up and running
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 09:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 11:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 08:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-05-2005 12:20 AM
SEO by vBSEO 3.5.0
