Old 07-09-2010, 10:18 AM   #1081
hi all, can a tb03 spool be used in a ta05 ifs ?
incubus is offline   Reply With Quote
Old 08-22-2010, 02:34 AM   #1082
Hi There,
Bit of a simple question but I've built my stock TA-05 IFS kit and put a Team Novak Havoc Pro Ballistic 13.5T Brushless System in it.
I want to gear it to run it faster and from what I can work out the gears in the car are either 0.6 module of 48P - is that one in the same???
I want to order some bigger spur gears and perhaps a larger pinion than the stock one.
Thanks for your help.
fritzzz is offline   Reply With Quote
Old 08-29-2010, 05:48 PM   #1083
Firefox's Avatar
Default IFS vs V2
Which car is most desireable and why, the IFS or the V2 ?
thanks
Firefox is offline   Reply With Quote
Old 08-29-2010, 09:36 PM   #1084
Foxxrocket's Avatar
thanks
The Version 2 is newer, so parts will be easier to find, and it fixes a few things from the original car. They almost look the same, but look hard enough and you'll see the difference between the two.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 08-29-2010, 10:35 PM   #1085
Originally Posted by fritzzz View Post
Hi There,
Yup it's tamiya 0.6 modules. You can just chane the main spur to a .48 one if you wish? I use a 105t 0.4 module spur on mine
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 10-06-2010, 03:49 PM   #1086
Can I use regular 64 pitch pinion with the 0.4 module 105 tooth spur?
Pete
pistol974 is offline   Reply With Quote
Old 12-06-2010, 12:21 PM   #1087
Wild Wolf's Avatar
Send a message via AIM to Wild Wolf Send a message via Yahoo to Wild Wolf
Pete
No. 64 pitch cannot be used with the metric .4 module.
You run the risk of stripping the teeth on the spur gear.
Best thing to do is convert the spur gear to a 64 pitch.
On my TA05-IFS, I'm running 48 pitch pinion and spur.
Just went to my local hobby shop and they were able to match up the correct spur to get rid of the metric gear of the tamiya.
Plus, the adds benefit is it makes it easier to change gears by that I mean it gives you more gearing options.
"Not knowing when the dawn will come I open every door." - Emily Dickinson
Team Associated - Team Factory T4, B4, B44, TC6
RDLogics - SHO
HPI - WR8 3.0
Tamiya - TA05-IFS (for drifting and TC)
Wild Wolf is offline   Reply With Quote
Old 12-06-2010, 12:32 PM   #1088
Wild Wolf's Avatar
thanks
I would go with the TA05 V2...the V2 is just the newer version and they upgraded and fixed some issues from the first version.
As for the IFS, although nice and different from the rest, in my opinion the TA05 is easier to set up as you have less adjustments then the IFS. Also, it's easier to find parts for the non IFS.
I live in California, and it seems whenever I need parts for my IFS I'm having to order them online.....and 90% of the time the parts are coming from Japan.
Where if I had the none IFS, my local hobby stores have the parts for those.
Yes some parts are interchangeable, but not all of them...So, if you get a IFS, Just make sure when you order hop up parts, that those parts are for the IFS and not the non IFS...otherwise you'll run into headaches trying to modify your car to use the non IFS parts on the IFS.
RDLogics - SHO
HPI - WR8 3.0
Old 12-28-2010, 12:34 AM   #1089
izzyracer's Avatar
Trader Rating: 27 (100%+)
One for sale here Tamiya TA05-IFS
Izzy
izzyracer is offline   Reply With Quote
Old 12-31-2010, 06:54 PM   #1090
Does anyone know if there's a retailer or seller that sells a conversion kit of all the necessary parts to go from a TA05 to a TA05-IFS. I have one a hopped up TA05 that I bought a while back and would like to make the conversion to IFS so I can use a particular body.
soulstice is offline   Reply With Quote
Old 12-31-2010, 07:04 PM   #1091
stitchy's Avatar
http://www.tamiyausa.com/articles/fe...article-id=384
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-31-2010, 07:50 PM   #1092
Firefox's Avatar
Originally Posted by stitchy View Post
Is the parts list the same to convert to the V2 TA05 ?
Old 12-31-2010, 09:48 PM   #1093
stitchy's Avatar
no, only from regular TA05 to IFS
Old 12-31-2010, 09:51 PM   #1094
Firefox's Avatar
Can the regular TA05 be converted to a TA05V2 ?
Old 12-31-2010, 10:10 PM   #1095
OverGeared's Avatar
Can somebody please confirm...
Are the front and rear belts of the TA05 series cars compatible with my TA05 MS?
Thanks.
OverGeared is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
