Old 06-01-2010, 04:10 AM   #1066
Andysan's Avatar
Alright, just shout if you want picture os my mounting setup.
Anyone any thoughts on rear suspension mounts for the above track please? Thanks.
Andysan is offline   Reply With Quote
Old 06-01-2010, 04:45 AM   #1067
HarryN's Avatar
Send a message via AIM to HarryN
Originally Posted by fritzzz View Post
Thanks, I ended up having to go with Option 2 as I also need to be able to see the LEDs on the ESC for various programming options etc. It's all come up pretty well but getting the cap to the brace is a bit tricky so I've wired it all in together for the moment and will look at it again on the weekend.
Wow, need to shorten them wires!!
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 06-01-2010, 05:13 AM   #1068
Yeah I know but the plan is to pull it out and move it between cars and I don't want to have to solder and unsolder and then resolder etc.
fritzzz is offline   Reply With Quote
Old 06-01-2010, 06:25 AM   #1069
HarryN's Avatar
Can you find an "in-between" size that works for both cars you are swapping? Not saying that the current length is going to hurt anything, but it is usually neater to have shorter wires.
But this is just an aesthetic thing, in my opinion.
Old 06-01-2010, 03:19 PM   #1070
I haven't worked out the next car to swap it into so for the moment I'll live with how it looks and then once I can try it in the next I'll shorten the wires to suit. If I find I never swap it I'll shorten them as well. I do agree it looks a bit messy!
Old 06-14-2010, 11:57 AM   #1071
StarrRacing's Avatar
Default HELP.... Front Steering and Drive Shaft Problems
Hello everyone...
My son and I both have TA05-ifs' and we are both experiencing the same problem....
On occasion when we clip a barrier, our steering sticks (I think to the right).... (mostly)...
And, we both experience our front "dog-bone" axels popping out...
I would think there is a fix for this....
We bought some CVDs, that were recommended, but they "still" seem to be to short.... and they pop out also....
Can anyone give us a recommendention to fix this problem?
Thank You
Please , any suggestion will help,,,
ThankX
Jeff Starr
U.S. Coast Guard (Retired)
Traxxas 4x4 (x2), Associated SC10,
XRay T3 '009 (VTA), XRay T3 '10 (USGT), Tamiya M05 (Mini),
Tekin, Spektrum.
StarrRacing is offline   Reply With Quote
Old 06-14-2010, 12:00 PM   #1072
Andysan's Avatar
Originally Posted by StarrRacing View Post
Hello everyone...
With the least amount of impact on the fron wheels around a corner, we either get the steering servo "locked" to the right, or our front "dog-boine" axles pop out... I would think there is a fix for this....
ThankX
Think you can solve this by putting a little bit of foam/rubber into your outdrives. Leave a little bit of play though.
Old 06-14-2010, 12:13 PM   #1073
HarryN's Avatar
Hello everyone...
Thank You
ThankX
What size are your CVDs? Are they 46mm or 44mm?
Old 06-14-2010, 12:23 PM   #1074
luketob's Avatar
You need to use 46mm CVD's up front especially if you run minimal front camber.
luketob is offline   Reply With Quote
Old 06-14-2010, 01:00 PM   #1075
Originally Posted by Andysan View Post
I'm in a similar scenario as I run a TA05 IFS with gear that goes in and out of my Associated T3. First of all if you're OK with the soldering I would cut the wires down a bit, they're surely longer than you would need foor any other model but those are just my thoughts.
Regarding ESC layout, I personally would rule out option 2 with the solder tabs facing the outside of the chassis - if you took a particularly hard hit these would likely break which is not cool.
I think option 1 is your best bet as your leads are away from the belt. What I would also recommend are a few tips I use; first, rotate the motor can counter-clockwise so that the solder tabs are at 9 o'clock; this is a little dangerous as they could get hit in a crash but they could still get hit at 12 o'clock anyway. This means the distance between your motor tabs and your ESC is longer so your leads dont look so obviously overly long. You could buy a short sensor lead for a few dollars also.
Also, the rear chassis brace is a great spot for mounting your capacitor - if you look closely it has a little slot in it that you can fit a couple of tie wraps through. Place your capacitor onto of the brace and loop the tie wraps through the brace - keeps it secure, out of the way of moving parts and looks hella cool.
Now I have a few IFS questions of my own - I recently bought a TA05-R and now have an IFS that has been gifted to me from a fellow racer. I have reset the IFS to the completely stock setup and have noticed that the rear suspension arms on the IFS are on backwards. I know that this offers "more suspension options" according to the product blurb but what are the advantages and disadvantages in detail please? Put simply, can anyone advise which way around to run the arms and which mounting holes to use on the arms and tower for a track such as this one please (running yellow springs all round)?
+ YouTube Video
Thanks in advance!
Hello, Please tell me where this track is located, It looks pretty awsome!!
Jeff Starr
Tekin, Spektrum.
Old 06-15-2010, 12:32 AM   #1076
Jay_P's Avatar
That would be Broxtowe in the UK, one of my favorite tracks when the Tamiya Eurocup was running
Jay_P is offline   Reply With Quote
Old 06-15-2010, 05:01 PM   #1077
Andysan's Avatar
Hey Jeff,
Yeah, Jay_P beat me to it, its Broxtowe in the UK. Went down a week ago for a day of racing but being Britain it was of course a wash-out. At the 2.45 mark, my car is the one in front of the car that the camera is chasing in that video!!!
Can I ask you, what was it like working as part of the US Coast Guard please? I have always yearned to do something that makes the adrenaline flow and provides a service to others, but want to know what the reality is like.
Thanks, and pleased to meet you from the UK!
Old 06-17-2010, 05:43 PM   #1078
TJ
TJ's Avatar
Hi guys i have been running a IFS for some time now. I have setup the front end as per instruction but I know that there are many adjustments that can be made in the rockers by spacing out the ball studs. What does this do and how does it work? I am after a setup for carpet with foams and wanted to know how the IFS works in this manner.
cheers
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 06-18-2010, 05:25 PM   #1079
Andysan's Avatar
Hi all,
Ran my IFS car for the first time last night having only ever used it as a standby car until then. The car felt very loose at the rear when getting on the power out of the corners, and a little vague on the way into the corners - not a lot of initial turn-in and then suddenly the car will either spin mid corner or spin on the way out under power. Running red springs rear and yellows on the front.
I also noticed my rear diff kept tightening itself up - which element of the diff do I need to address to prevent this from happening please?
Would be grateful for any setup tips as I have a big race on Sunday. Cheers!
Old 06-18-2010, 06:00 PM   #1080
GREGORY!'s Avatar
hi guys.i want to ask which dampers are better the fluorine coating or the hard black coating and why.
thanks!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is online now   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
