Old 01-20-2010, 12:11 PM   #1036
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by <PsOp> View Post
How do you guys fix chassis tweak?
if you are using the tub chassis it's already tweaked , it has been discussed in the TA05 forum. That's the reason why I opted for the CF chassis (aftermarket, hop-up option which are made by diff. companies)
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-21-2010, 01:17 PM   #1037
Ok, so whats the best gear ratio to start with? looking for a higher top end speed and using a 3.5 t brushless lrp x12?
Jamie24 is offline   Reply With Quote
Old 01-26-2010, 03:26 PM   #1038
Hi guys,
New to RC in general and the IFS is my first RC car! I've been getting on with it fairly well since purchase and am now growing in confidence a bit and after asking around have been told that the most worthy options to go for first are TRF shocks and front CVD's instead of using dogbones, would you guys agree that's good advice?.
Will any TRF shock fit? For example will parts 42102 or 53571 be ok for the shocks? For the CVD's I'm assuming the shaft and axel will need to be replaced to that used on the IFS-R or can the set from the TRF 415 be used? Do either bolt straight on?
EDIT: Found page 18 in the manual which has cleared 1.5 questions, still wouldn't mind knowing if 42102 would fit as well as they are much easier for me to get hold of.
Apologies if this has been asked before I've been through a fair bit of this thread and can't seem to find the answers.
Cheers
Gaz
gazmond is offline   Reply With Quote
Old 02-27-2010, 07:52 PM   #1039
modernarts01's Avatar
Smile
Originally Posted by gazmond View Post
Hi guys,
Cheers
Gaz
I'm pretty sure that any TRF shocks would fit in a TA05, that's what my hobby parts supplier said. Of course you would have to use the required size ball studs to pop them on your chassis of course.
As for your first question. Yes, i would suggest having TRF shocks and Universal Swing Shafts as your first upgrades on your list, as well as the Tamiya bearing rocker arms for your front suspension is a good add on as well since it makes your front suspension more solid feeling and smoother ^_^. I'm actually using my IFS for drifting for the time being with a countersteer set up, it's also a great racing chassis. It's just a great car in general.
For the CVDs, I'm not sure if either those will fit right on. I'm guessing that as long as they're 46mm they should fit =P. Well, good luck man and great choice for a first chassis.
modernarts01 is offline   Reply With Quote
Old 03-06-2010, 11:03 AM   #1040
energyracing's Avatar
3rd round Tamiya Champioship Series Pics on ENERGYRACING.
http://energyracing.tripod.com
George B.
energyracing@hotmail.com
Sponsored by Serpent / SRX2 MM, RM, SC / Serpent SRX4
MoFo paints
energyracing is offline   Reply With Quote
Old 03-10-2010, 10:16 AM   #1041
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Default Setup sheet
I have had some people asking me for this from the V2 thread but my car isnt a V2 so I will post it here......a PDF sheet of the setup that Im currently using on carpet and what I used at the TCS race in Omaha. Whats not on the sheet is that I use the carbon lower chassis. Also I run this setup with a spool or a 1way....if traction is lower a spool is better when its gets higher a 1-way works better.
Any questions feel free to ask....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-11-2010, 04:00 PM   #1042
Tsquare's Avatar
Does anyone have the parts listing needed to convert a TA05 IFS to a V2??
Tsquare is offline   Reply With Quote
Old 03-11-2010, 04:07 PM   #1043
Kevin K's Avatar
I dont have part numbers....but if you are starting with a type R this is what you need....
Chassis
Motor mount
Lay Shaft
Spur gear adapter
Steering rack...same as TB03
K-parts tree
Split suspension mounts for front rear arm mount and rear front arm mounts
From looking to convert my IFS-R over to a V2 this is what I would need to order as best I can tell.
If you dont have a type R there are a whole lot of other parts....all the suspension, drive train(belts and pulleys) plus all the above parts.
Old 03-11-2010, 07:23 PM   #1044
Tsquare's Avatar
Chassis
Motor mount
Lay Shaft
Spur gear adapter
K-parts tree
Thank you - I am converting an "R"
Old 03-21-2010, 02:50 PM   #1045
Fat Corgi's Avatar
Originally Posted by gimpex View Post
Is there any advantage (or otherwise) to using the wide pitch 36T pulley ( 49472 ) as a replacement for the standard white kit pulley. The wide pitch one, has every second tooth missing,...
I'm interested in an answer on this one as well. Any one?
Fat Corgi is offline   Reply With Quote
Old 03-21-2010, 03:02 PM   #1046
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Here is a link to the V2 forum.
TA-05 ver.2
Check post 841.
SerpentCT4S is offline   Reply With Quote
Old 03-22-2010, 05:18 AM   #1047
Mr LowDown's Avatar
Trader Rating: 21 (100%+)
hi guys..
i'm running my TA05-IFS for 48T SSGP race..
now i'm torn between LRP Quantum3 or KO VFS1 competition2 esc..
it's for my SSGP brushed motor..
which one should i choose?
LRP got lipo cut off but 10 minutes race with 5600mAh lipo
Any no auto lipo cut off esc will not harm my lipo
i'm using my mamba max for practice
since it got brushed and brushless mode with auto lipo protection
so i can bash till the esc cut off automatically
but i want an esc that specifically design for brushed motor
from my observation these 2 came out on top..
can u guys give me advice on which one to buy?
the lucky ESC will be for race use only..
Mr LowDown is offline   Reply With Quote
Old 03-23-2010, 04:52 PM   #1048
Whats the part number for the black rims (spoked) that will fit the Ta05? I have a TCS race coming up and I dont have a book. Not sure offsets or how big they need to be. Im running the GT3 class
G_Anders is offline   Reply With Quote
Old 03-28-2010, 09:36 AM   #1049
Mr LowDown's Avatar
can i use 416's suspension mount onto my ta05?
Old 04-07-2010, 12:38 AM   #1050
Fat Corgi's Avatar
Default Front Universals
Hi there,
I'm trying to fit universals to the front of my IFS and can't manage to get the right set up. So far I have bought...
46mm Assembly Universal Shafts (53847)
48mm Swing Shafts (53836)
It seems that the outer axles now are too long as there is a 2mm gap between the pin and hex block and the outer bearings.
Any thoughts?
Help appreciated.
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
