Old 10-05-2009, 10:15 PM   #1006
niznai's Avatar
Originally Posted by RossoTorro View Post
I got a converted TA05-R to TA05 IFS-R.
It has lots of options...
53883 TA05 carbon steering link
53893 Lightweight carbon lower deck
53990 TA05 alu bulkhead
53994 TA05 IFS rear carbon damper stay
54019 TA05 IFS alu bulkhead
There are some more, can't remember them. Also the steering and rocker arms have bearings in them.
My problem is.... I tried the chassi on 4 seperate scales to weigh it in with lipo.
I then saw the difference in weight on each wheel. What puzzle me is the way it was distributed.
Front left was 370g
Rear right was 380g
Front right was 240g
Rear left was 250g
Why are the weight so unusual? Just to get a basis and that the place i measured was straight i also tested my TA04-R and that was 10g to 20g off on each corner.
My guess is the chassi has tweak in it, but it's brand new. I changed oil in dampers and put on new springs. No difference. I took the car apart to see and found nothing wrong.
Anyone have a clue?
Scales calibrated correctly and within tolerance of each other?
Try removing (disconnecting) the suspension (i.e. the shocks from the lower arms. That way, you will get only the contribution of weight in each scale reading (i.e. the springs will not transfer any load to the opposing corner - which is what they do).
Tweak on a brand new car is not inimaginable, but it is worth checking the chassis first with a straightedge if you have one. Start as above and work you way down from there.
If one corner is loaded more, then to achieve the same ground clearance you will need to put more load on the spring, thus transferring some of the weight to the opposite corner. If all the above tests are clear, then you need to re-distribute the weight around in your car.
One other way you can tackle this is to just balance the car on needlepoints (like the Hudy chassis balancing tools; you don't need to buy them, just make your own). That way weight transferred by spring load is taken out of the equation.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 10-05-2009, 11:10 PM   #1007
Skitee's Avatar
Anyone have a clue?
The TA-05 tubs have been discussed extensively in the TA-05 thread for that very reason, I've bought new plastic tubs and the lightweight FRP tub and they both had tweak straight from the packet when they were put on a flat surface. When I converted my IFS-R to a Ver.II I checked that tub for tweak too and it was much better than on the original TA-05 tubs.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 10-06-2009, 02:22 AM   #1008
niznai's Avatar
This is the problem with molding plastics. If they get pulled of the mold too quickly they'll distort. Are these still molded in Japan or did they move production elsewhere?
I was lucky I suppose but both my upgrade CF and the plastic one that came with the kit (TA05R) are tweak free.
Team Greasy Weasel
Old 10-07-2009, 03:40 PM   #1009
zangonli's Avatar
Default ta05 ball differential thrust bearing
Hi folks,
I think I need to replace the thrust bearing in my ta05 ball differential. Will Tamiya part no. 53136 (OP-136) work?
Thanks much.
Farzad
zangonli is offline   Reply With Quote
Old 10-08-2009, 12:34 AM   #1010
Skitee's Avatar
You need to use 9949300.
Old 10-20-2009, 11:44 AM   #1011
Juanchoyo's Avatar
Hi guys, long time since my last post...
But i have a question
...... Where can I get a brand new IFS-R ??? They seem to be extincted now!! LOL
Every online store I've tried... OUT OF STOCK....
Maybe the only way is to find an used one here in RC-TEch?
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 10-20-2009, 04:37 PM   #1012
cheehtae's Avatar
Trader Rating: 15 (100%+)
try tamiyausa.com
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-20-2009, 07:43 PM   #1013
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Dinballrcmart.com they only have the V.2 Right now....http://www.rcmart.com/catalog/rc-tam...cPath=420_1167
Slotmachine is offline   Reply With Quote
Old 10-20-2009, 11:27 PM   #1014
Skitee's Avatar
I wouldn't bet on seeing any IFS-R's before the Ver.II R is released.
Old 10-21-2009, 05:46 AM   #1015
cheehtae's Avatar
hey slot nice to hear from you again, what kind of 05 are you driving right now?
Old 10-22-2009, 07:45 AM   #1016
Juanchoyo's Avatar
Yeah but it's veeeeery expensive at TamiyaUSA.com, and it seems for me V.2 is very expensive, it doesnt include the good stuff of an R. Is it really worth the V.2 vs the v.1 for such a difference in price???
FoxRC Hobby Club
Old 10-27-2009, 08:14 AM   #1017
AWK
AWK's Avatar
That kit has been discontinued so eBay would be your best bet. We have been out of stock for about 7 months.
AWK is offline   Reply With Quote
Old 11-15-2009, 12:35 AM   #1018
Default Wide pitch pulley
Is there any advantage (or otherwise) to using the wide pitch 36T pulley ( 49472 ) as a replacement for the standard white kit pulley. The wide pitch one , has every second tooth missing , and from the side it only has holes for the balls with a rim where the original pulley has other holes on the outer perimeter.
I bought it as a replacement for the rear , but the question applies to front or rear.
gimpex is offline   Reply With Quote
Old 11-16-2009, 08:26 PM   #1019
Hello everyone,
If anyone is interested in a TA05MS new in box, check out this link.
Tamiya TA05MS KIT NEW IN BOX For Sale
Obsidian is offline   Reply With Quote
Old 11-30-2009, 07:28 PM   #1020
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
What is the length of the stock IFS shocks?
mrrcguy is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
