Old 07-21-2009, 05:36 AM   #991
Default Question about trimming rear spoiler on EBBRO BTEC Maziora 350R
Hi,
I'm just up to painting my EBBRO BTEC Maziora 350R and there is a separate piece for the rear of the body.
In the manual it says to trim outside the cut line but can anyone tell me how far outside?
The cut lines there are a bit confusing - it looks like there is a middle line in between two outer lines rather than an inner line and an outer line.
Any help would be appreciated.
Thanks!
fritzzz is offline   Reply With Quote
Old 07-22-2009, 04:16 AM   #992
what springkit is the right one for the trf shocks on the ta05? havent had tamiya before now i see that there is alot of different spring kits
i ordered yellow springs and got 53631 TRF short damper spring, that cant be the right one? its shorter than my std springs?
Hatebreed is offline   Reply With Quote
Old 07-22-2009, 06:08 AM   #993
Default DIFF
DOES THE TA05 DIFF FIT TA-O4 ?
racingkids is offline   Reply With Quote
Old 07-22-2009, 08:42 AM   #994
Skitee's Avatar
Originally Posted by fritzzz View Post
Hi,
Thanks!
Just cut around the edge of the trim line instead of on the trim line.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-22-2009, 08:44 AM   #995
Skitee's Avatar
No it doesn't fit
Old 07-22-2009, 04:51 PM   #996
Thanks Skitee - all good, will cut it out tonight.
Cheers
Old 07-25-2009, 04:20 PM   #997
cheehtae's Avatar
Trader Rating: 15 (100%+)
those are for mini's, I think. this is what you need.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWB01&P=7
cheehtae is offline   Reply With Quote
Old 07-30-2009, 10:58 PM   #998
R1wurks's Avatar
R1wurks Pro dual cooling fan kit is now in stock. $35
This is the same fan kit used by Lee Passehl,2009 TCS Regionals GT2 winner @ the tamiya track in Aliso Viejo,CA.
the complete kit comes with all the hardware necessary to install.
1) R1wurks Pro dual fan mount (only 5grams)
2) 2 25x25x10 high power fans rated at 2.8cfm each @ 5volts,Pre-wired "y" harness(plug & play)
3) 5pcs m3x14mm socket head cap screws
you can also order thru r1wurks@r1wurks.com
dealer inquirys please email r1wurks@r1wurks.com
R1wurks is offline   Reply With Quote
Old 07-31-2009, 02:01 AM   #999
Does anyone have any Red Surikarn Tamiya shocks they want to sell?
DOTMAN is offline   Reply With Quote
Old 07-31-2009, 08:47 AM   #1000
94eg!'s Avatar
Trader Rating: 17 (100%+)
You can easily make them yourself by purchasing the red shock parts on the TamiyaUSA website. They've been on sale for last year for pretty cheap too...
Actually it looks like they're out of the read adjusting collars, but you can still find them on eBay or some HK store for cheap:
http://www.tamiyausa.com/product/sal...e=2&view=items
94eg! is offline   Reply With Quote
Old 07-31-2009, 11:00 AM   #1001
Awesome...thanks for the info
Old 08-15-2009, 09:43 AM   #1002
Default 51103
Has anyone tried 51103 (TB Evo IV C parts - Front Upright) on TA05-IFS? Is it carbon reinforced material? From the look of it, it looks the same as 51296 (TA05-IFS Front Upright), but harder. CMIIW.
xniperliams is offline   Reply With Quote
Old 08-16-2009, 05:33 PM   #1003
RossoTorro's Avatar
I got a converted TA05-R to TA05 IFS-R.
It has lots of options...
53883 TA05 carbon steering link
53893 Lightweight carbon lower deck
53990 TA05 alu bulkhead
53994 TA05 IFS rear carbon damper stay
54019 TA05 IFS alu bulkhead
There are some more, can't remember them. Also the steering and rocker arms have bearings in them.
My problem is.... I tried the chassi on 4 seperate scales to weigh it in with lipo.
I then saw the difference in weight on each wheel. What puzzle me is the way it was distributed.
Front left was 370g
Rear right was 380g
Front right was 240g
Rear left was 250g
Why are the weight so unusual? Just to get a basis and that the place i measured was straight i also tested my TA04-R and that was 10g to 20g off on each corner.
My guess is the chassi has tweak in it, but it's brand new. I changed oil in dampers and put on new springs. No difference. I took the car apart to see and found nothing wrong.
Anyone have a clue?
RossoTorro is offline   Reply With Quote
Old 09-11-2009, 04:00 PM   #1004
cheehtae's Avatar
where can I purchase belt and other stuff for the IFS-R?
Old 10-05-2009, 04:10 PM   #1005
inconceivable's Avatar
Does anyone have a carpet / rubber tire set up, or know of a link to one ? Thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
