Old 06-26-2009, 05:48 AM   #976
Trader Rating: 17 (100%+)
Originally Posted by xniperliams View Post
Anyone have problem with KO Propo servo? I am using 2501 in particular. It seems it is a bit wider than other servos.
I previously used a standard servo that came with Sanwa MX-A Tx and had no problem fitting it in. But with 2501, the long screw that goes from the bottom up of the tub had to kind of lean to the outer side of the tub.
The servo saver also touched the tub so I had to use a filer and made a "dip" (not sure the right word for this) so it could make a turn all the way to the left with no problem. Is this legal for TCS anyway?
Appreciate your advice. Thanks.
Did you trim off one of the mounting ears as in instructions?
I use a Futaba 9551, and I cut down the kit's servo mounts so the servo could be moved back enough to mount the steering link on the front of servo saver.
Yes you can cut tub for clearance because it's in the instructions too. Bring the instructions with you just in case to prove it.
billb60 is offline   Reply With Quote
Old 06-26-2009, 07:47 PM   #977
Yes I trimmed off one of the mouting ears. I think this has to be done or the servo just won't fit in. But it still didn't fit in nicely like the Sanwa servo. It is kind of 1mm longer than the Sanwa one. Also the servo rotating gear seems a bit further to the left by a few millimeters, hence the need to trim the tub for clearance.
You are cutting down the servo mount so it becomes shorter, right? I would consider doing this. If the servo moves back further, I may not need to trim the tub anymore in the future because the tub gets wider further back.
But where exactly in the instructions does it say the tub can be cut for clearance? I couldn't find it.
But I am really interested to see if anyone with KO Propo servo having the same problem. Thanks for the suggestion.
xniperliams is offline   Reply With Quote
Old 06-27-2009, 12:28 AM   #978
KO servo fits perfiectly in my cars.
DirtyRacer is offline   Reply With Quote
Old 06-27-2009, 10:15 AM   #979
What model of KO Propo servo are you using?
Old 07-12-2009, 11:52 PM   #980
dameetz's Avatar
Any performance difference if I change my stock normal chassis and suspension arms to lightweight carbon composite chassis and short reversible arms? What other things should I buy along if I wanted to use the short reversible arms? Suspension block/bridges? CVD length? Uprights?
Thanks!
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-14-2009, 09:51 PM   #981
dameetz's Avatar
Thanks!
Bump.
Anyone?
Old 07-15-2009, 09:28 AM   #982
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks!
yes there will be a huge performance difference. the carbon tub is lighter and stiffer. short reversible arms will also affect handling. your car will behave differently.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-15-2009, 09:47 AM   #983
dameetz's Avatar
So do I need to change the suspension block/bridge? I m using 415 blocks at the moment. Also what length of CVD should I use?
Old 07-15-2009, 11:05 AM   #984
Thanks!
This article is more about how to convert to IFS but it gives the swing axle part numbers towards the end of article
http://www.tamiyausa.com/articles/fe...article-id=384
Old 07-15-2009, 05:12 PM   #985
I have asked this before but havent got a good answer yet
what is the benefit in handling of having the IFS compared to the standard stand up shocks in the front? (exept that i can run lower bodies)
i bought a IFS-R but has only driven it with stand up shocks because that is what i have been doing all these years, but havent bothered to try the ifs, but now i`m a little corious about it
also, what rate does the tamiya #500 shockoil compare to? From what i understand it should be something like associated 40wt?
Hatebreed is offline   Reply With Quote
Old 07-16-2009, 12:08 PM   #986
Trader Rating: 69 (100%+)
I know that with the IFS setup, adding spacers on the rocker arms gives the effect of moving the top shock position outwards.
is there something to do so the opposite will happen?
what i'd like to do is (visualizing the stock TA05) lay the front shocks inwards to achieve more traction.
Markus is offline   Reply With Quote
Old 07-17-2009, 07:07 AM   #987
need help!
im planning to buy an IFS or the TA05 ver 2.?
which is better?
is the TA05 capable to run competitively in 13.5T class. Ill be racing on a parking lot.
Thanks in advance!
SKYFLAKES is offline   Reply With Quote
Old 07-17-2009, 07:16 AM   #988
Skitee's Avatar
Go with the Ver.II it has a narrower tub and changed battery position and it comes standard with the IFS-R / 416 Pulleys, short reversible suspension arms and the TB-03 / 416 front and rear uprights.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-17-2009, 07:20 AM   #989
i notice that the ver II is pure stock, besides the shocks which part/s do i have or need to change to make the car competitive?
Old 07-17-2009, 07:30 AM   #990
Skitee's Avatar
Yes it is very stock but the older IFS kits were exactly the same only the R version had some bling in it.
You probably only need these hopups
TRF shocks
Rear carbon shock tower
Aluminium rocker arms
Aluminium steering arms
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
