Old 06-02-2009, 09:30 PM   #946
dameetz's Avatar
Originally Posted by reenmachine View Post
How do you define being at "full lock" if the flat on the front knuckle doesn't touch the C hub?
That's what "full lock" is...when the flat on the knuckle (designed for this purpose) rests against the C hub. On my TA05s (both std. and IFS) these stops make contact -- I had to turn my EPAs down to the point where they just make contact vs. really pushing hard. You don't need to do any "steering plate mod" to get there...
Like I said, the ball stud on the steering plate is limiting the steering angle, therefore I can see my knuckle has around 3-4mm gap to the C hub. I ll try to post some pics of it so everybody can have a look and understand it, as explaining it in words is something I m not good at...afterall English is not my mothertoungue.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 06-02-2009, 09:32 PM   #947
dameetz's Avatar
Originally Posted by BP SHADOW View Post
Not to be a jerk or anything, but have you actually run the car yet?
Sounds like you're making alot of assumptions based on appearances.
Most of the guys that I run with including myself that have the IFS report having plenty of steering. We run with the 416 and are plenty competitive.
If you want more steering, you could always go to the 2 degree c hubs vs the 4 degree which I believe are standard. From there you could adjust the amount of force on the rockers through spacers. The forward holes on the steering knuckles make the car pretty aggressive. Just my $.02
Yes I have driven it 4 times now on my local track on foam tyres....thanks for your set up advice, i ll try that soon...
Old 06-02-2009, 09:32 PM   #948
check your steering trim on your transmitter.
DirtyRacer is offline   Reply With Quote
Old 06-02-2009, 09:54 PM   #949
reenmachine's Avatar
Trader Rating: 26 (100%+)
Please do post a pic because I just can't see how this could be happening. How is the ball stud limiting the steering angle? Is it hitting something? It shouldn't come anywhere close to hitting anything.
BTW, mother tongue or not, your written English is better than 95% of the native speakers on here.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 06-03-2009, 04:35 AM   #950
try checking if you have the steering plate inverted....
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 06-03-2009, 07:41 AM   #951
94eg!'s Avatar
Trader Rating: 17 (100%+)
That would certainly do it. It's probably installed 180* around...
I've even run mine this way for more ackerman, and it worked fine. Penguin tells you to install the steering bridge this way too. Still had to dial down the dual-rate for our small parking lot track...
94eg! is offline   Reply With Quote
Old 06-03-2009, 11:10 AM   #952
Trader Rating: 8 (90%+)
I was hoping to grab a TA05 IFS-R to race this summer but it seems to be discontinued (par Tamiyausa's website)? Is Tamiya updating it with the newer v2 chassis?
TenzoR is offline   Reply With Quote
Old 06-03-2009, 02:18 PM   #953
AWK
AWK's Avatar
Tamiya is coming out with a TA05 Ver. II chassis this summer. It will be a TA05-IFS chassis with short suspension arms, a revised chassis, TA05MS style motor mount and larger IFS-R style pulleys: http://www.tamiyausa.com/product/ite...oduct-id=58435
AWK is offline   Reply With Quote
Old 06-04-2009, 01:21 PM   #954
Questions?? Static vs ESC
Has anybody ever had the static problem take out a ESC? On a stock TA05-IFS I've burnt out 5 tazers and 1 FXR. Taken it to the LHS they think every thing looks right. The car will run for about 1/2 a battery charge then white smoke, the fxr just stoped, no smoke. I've tried different batteries, from 15k nicads to 3300 nmih. Also have run both digital and standard servos, thought the BEC of the tazer couldn't handle the dig servo. The car has only been run on the street, never touched water.
scotk is offline   Reply With Quote
Old 06-04-2009, 01:59 PM   #955
Foxxrocket's Avatar
The plastic chassis builds up a lot of static electricity, because It isn't grounded. So, it'll spark up now and them. Same thing with my TC4, but I've never had an electrical problem with either of my cars.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 06-04-2009, 09:23 PM   #956
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I lost a couple of servos before I figured out what was up, but never a speedo. I made a groundstrap that goes from the motor mount to the rear bulkhead and havent had a problem since
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-05-2009, 12:33 AM   #957
BP Shadow, Is your chassis a R-chassis or std?
I made some ground straps, one each for the front and rear diffs to the motor mount. Ran 2 batteries through an old tekin 410k, I'm not sure if that means anything or not?
Old 06-05-2009, 05:18 AM   #958
BP SHADOW's Avatar
I am running the stock plastic tub. Supposedly switching to the carbon tub solves the problem, but I like the amount of compliance in the stock tub. You only really need to run 1 ground strap. A Tekin 410 k, wow, I have one of those, truly old school, but way ahead of its time
http://f1rclab.com
Old 06-08-2009, 07:46 PM   #959
Raced my new 05IFS on the weekend, box settings with the included silvercan. Only change was 24 compound tyres, came 3rd in stock class against 17.5t brushless cars with lipos Had heaps of steering, and it carried a fair amount of corner speed, which helped me overtake in the corners
xsnoizta05 is offline   Reply With Quote
Old 06-09-2009, 10:27 PM   #960
Goingfast's Avatar
Trader Rating: 29 (100%+)
Default TCS race
Who got the best set up for GT2 out door medium traction surface?
what hop up do i needs ? thanks
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Tamiya TT-01 RTR and Tamiya TA05 Roller FOR SALE nexxus Australia For Sale/Trade 9 11-07-2010 01:56 AM
WTB: Tamiya TA05 /R/IFS/IFS-R loriding69 R/C Items: Wanted to Buy 6 06-20-2008 08:34 PM
Tamiya TA05-ms E-clip Australia For Sale/Trade 4 06-11-2008 10:46 PM
FS: Tamiya TA05-R (TA05) TCS Legal limbohz R/C Items: For Sale/Trade 5 06-05-2008 07:58 PM
FS: Tamiya TA05 crzydrifter R/C Items: For Sale/Trade 6 11-04-2005 11:20 PM
